XRCDs ripped to HDD for BDP1
0 Members and 1 Guest are viewing this topic. Read 1485 times.
jjc1
« on: 30 May 2012, 07:07 pm »
Last night I came across an album (Hiroko Kikubu.. "New York Uncovered") which I ripped from an XRCD24 and was playing thru my BDP1. Wow! This sounded as good as or better than any Hi Rez download I have. It definitely sounded better than normal CDs ripped to a hard drive, even those which are well recorded and engineered CDs. I then searched for other XRCD rips I had and they too sounded great.
  Anyone else have this experience? Seems as though XRCD rips and the BDP1 work very well together.
Sasha
Re: XRCDs ripped to HDD for BDP1
« Reply #1 on: 30 May 2012, 07:27 pm »
XRCD does not differ in word depth or sampling frequency from standard redbook CD format, it is just a specific set of mastering and manufacturing steps.
ronman
« Reply #2 on: 4 Jun 2012, 03:44 pm »
I have always enjoyed the Stockfish XRCD24's. "Closer to the Music" collection, Sara K, (and others) spring to mind. The cd covers say they are 24bit recordings. When I ripped the XRCDs to hard drive I changed the default rip setting from 16bit to 24bit in the hopes that I would not "damage" the ripped version. Haven't done any A-B-A comparisons but decent original recordings are always appreciated.
srb
« Reply #3 on: 4 Jun 2012, 03:54 pm »
The recording may have been recorded at 24bit resolution but was mastered to the CD in 16 bit format.  Ripping at 24bit won't gain you anything, but I don't think the added 8 bits of 0 padding would hurt anything either, but it does increase your filesize by 50%.
ronman
« Reply #4 on: 4 Jun 2012, 09:09 pm »
Hi srb
What you say makes sense. And I did notice an increase in file size. Wasn't too concerned as there's plenty of hard drive space.
