0 Members and 1 Guest are viewing this topic. Read 3435 times.
Did you happen to get a service manual for the EC-1, while you were a member at VE? It could come in handy, but you might not need it. If you have it, look for any special procedures for disassembly and the wiring scheme. Remove the dust cover, headshell, counterweight, and platter. Tie down the arm. Then figure out how you're going to support it when you remove the feet and bottom panel. (Hint- protective cloth over bricks or other structure, perhaps an old chair with the bottom removed and rigged for TT repair.) If the dust cover is sturdy, you might get away with putting down a cloth and resting it on the cover. That's not recommended. You might see the tonearm wires exiting the pillar without having to remove anything else. On an automatic, often the wires go to a junction. Hopefully, it will be straightforward and you'll see the problem. Sometimes the ground wire is bundled with others at that junction, but first you have to see what's going on.
Well, it's a good news/bad news story. Took the deck apart, and the good news is there is no problem with the tonearm wiring or any soldered connections. I swapped the longhorned Grado Gold1/8MZ combo out after putting the deck back together, and put in my AT 440mla. No hum, nothing. I don't know if somehow the Grado got damaged internally. I'm going to replace the headshell leads and put it on another deck and see what happens. Thanks to everyone for the suggestions/encouragement.
Could be the headshell leads. I have a Magnepan Unitrac that has a removeable headshell with tiny leads that go to a small plug that fits on a tiny male recepticle on the end of the arm. One of them will occasionally hum when I remount a different cartridge....usually just removing the plug and re seating it does the trick, or redressing the hair like leads.Russellc
