SOLD: MTM GR-Research / Vifa Ring Radiator project - SOLD
0 Members and 1 Guest are viewing this topic. Read 3104 times.
walkern
I'm MOVING!  ARRRGGGHHH!!!!  Am forced to sell projects that I never quite got dialed in.  This one is an MTM PAIR of speakers using GR Research M-130 midbass drivers (16 ohm versions) above and below a Vifa XT Ring Radiator tweeter.  These are mounted in sealed Parts Express .75 Cu Ft Cherry veneered enclosures.  I never got a crossover that I was happy with, and even tried running the GRs full range with the tweeter set to extend the response with just a simple single cap.  In any case, you could buy crossovers and B&G tweeters from Danny and make these into a current model N3-S.  Or you could just experiment with xovers (as I had been doing) until you get something that works.  The cabinets are in very good but not perfect shape, in original boxes, lined with No Rez.  I just want these to go to someone who will put them to good use.  Asking $125 plus will split shipping.
« Last Edit: 3 Jul 2012, 11:29 pm by walkern »
walkern
Re: FS: MTM GR-Research / Vifa Ring Radiator project
« Reply #1 on: 14 Jun 2012, 11:52 am »
Bump.  Still hoping to not have to move these.
walkern
« Reply #2 on: 25 Jun 2012, 01:23 pm »
Lowering the price to $125 and I will split shipping here in CONUS (each speaker in it's dedicated box weighs 32 pounds).  Also, I should have mentioned that the M-130s have been enABLed using the Planet 10 kit.  Also one other note of interest... the grills do not 'fit' or remain attached because the M-130s are surface mounted and protrude enough to space the grills off the baffle.  If you want the grills to attach, you could always flush mount the M-130s, or mod the grill frames to accommodate the M-130s.  Grills were not important to me, and have never been used.
There is almost $400 worth of parts here!  Please somebody take them off my hands so I don't have to move them?!?
hdspeakerman
« Reply #3 on: 25 Jun 2012, 09:12 pm »
What model is the Vifa tweeter?
howard
walkern
« Reply #4 on: 27 Jun 2012, 04:15 pm »
Don't remember the full model number, and I'm at work at the moment.  All I remember is it is an XT25 BG something, and if memory serves, it is the 8 ohm version.  I'll check when I get home and post another reply then.
walkern
« Reply #5 on: 27 Jun 2012, 11:39 pm »
Okay, the tweeters are Vifa XT25TG30-04... so not the 8 ohm version I was presuming.
