Audio/Video Gear and Systems
All Solid State
Low(er) Gain Amps
Low(er) Gain Amps
0 Members and 1 Guest are viewing this topic. Read 1963 times.
sts9fan
Volunteer
Half Assed Hobbyist
Low(er) Gain Amps
29 May 2012, 12:03 pm »
Anyone know of amps with gain ~20db? I know of the First Watt line so other then that. I don't understand why power amps all have 30+ db of gain. It's so unnecessary.
roscoeiii
Re: Low(er) Gain Amps
29 May 2012, 12:44 pm »
Hmm 20 will be tough to find. Most don't go below 26 dB.
I really liked the ability to decrease the gain on my Atmasphere amp by inserting some jumpers in place of 2 6SN7s.
Diamond Dog
Chameleon, Comedian, Corinthian and Caricature
Reply #2 on:
29 May 2012, 01:26 pm »
+1 that finding 20dB could be an epic quest. My Bryston 7BSST2's are switchable from 29 to 23 dB and I do use the lower setting.
D.D.
werd
Reply #3 on:
29 May 2012, 01:44 pm »
I use my 14B at 23 db also. I am not sure I would want to go under 20 DB in amplification. I would look at moving down in a pre amp in adjusting overall system gain.
opnly bafld
Reply #4 on:
29 May 2012, 02:17 pm »
From a First Watt paper "So here we are in the New Millennium, and thanks to Tom Holman and
THX we’ve got lots of gain in our electronics. More gain than some of us
need or want. At least 10 db more."
cliffy
Reply #5 on:
Nuforce amps have low gain.
http://www.nuforce.com/hi/products/Monoamp/ref9v3se/index.php
21db.
Happy Hunting!
sts9fan
Volunteer
Half Assed Hobbyist
Reply #6 on:
29 May 2012, 06:51 pm »
23 is close enough to 20. I was just throwing out 20. My ZenV9 is 12db.
All Solid State
Low(er) Gain Amps
