Cheapest/Best way to get Android onto an HDTV??
0 Members and 1 Guest are viewing this topic. Read 1311 times.
eclein
« on: 27 May 2012, 11:55 pm »
I'm looking for an attach this box type solution to get Android and Google Play market etc..onto a HDTV with HDMI inputs. Is it Logitech Revue or another add on box solution thats best. I want to play games, mess with android apps on my 46" HDTV, anybody else doing that??? :thumb:
audioseduction
Re: Cheapest/Best way to get Android onto an HDTV??
« Reply #1 on: 4 Jun 2012, 08:55 pm »
Just place your Android device on top of the HDTV. It won't cost you a dime I promise.  :thumb:
jkelly
Doublej
« Reply #3 on: 16 Jun 2012, 01:00 pm »
Best - Just buy an Android tablet with a mini HDMI port and connect it to the TV via a mini HDMI to HDMI cable. Add a bluetooth keyboard for wireless control and you are good to go.
I think the Logitech Revue is being discontinued and Logitech is going to be dropping support so buyer be warned.
eclein
« Reply #4 on: 16 Jun 2012, 07:57 pm »
Doublej thats what I did and it works wonderfully, I forgot I had purchased a Mini HDMI to HDMI and found it, works great!! :thumb:
