Question about SACD/CD playing on a DVP-NS999ES
0 Members and 1 Guest are viewing this topic. Read 2465 times.
Whitese
« on: 27 May 2012, 09:40 pm »
I have a Modwright Sony DVP-NS999ES Signature modification...before I put in a hybrid SACD, I choose SACD from the CD/SACD option from the remote control, but after a few seconds, the SACD logo turns off and it plays the disk on CD, as that little CD light turns on...
Any idea if that is normal with hybrids disks?
ted_b
Re: Question about SACD/CD playing on a DVP-NS999ES
« Reply #1 on: 27 May 2012, 09:45 pm »
No, choosing SACD should play the SACD layer.
Whitese
« Reply #2 on: 27 May 2012, 10:07 pm »
ohh, crap!!
DZetye
« Reply #3 on: 27 May 2012, 10:28 pm »
I think that your laser needs replacement.  Thats what happened to mine
Whitese
« Reply #4 on: 27 May 2012, 11:16 pm »
did you send it to Sony? I wonder if Modwright guys can do that?
DZetye
« Reply #6 on: 27 May 2012, 11:48 pm »
Modwright did mine.  call them or email Dan
Whitese
« Reply #7 on: 27 May 2012, 11:58 pm »
cool I will do so!
Whitese
« Reply #8 on: 28 May 2012, 04:08 pm »
Well, all of a sudden, I set it up using the video screen and it stays on SACD allright, but it freezes randomly for a few seconds...I guess it will end up happening anyway right, total freeze on the SACD layer...?
DTB300
« Reply #9 on: 29 May 2012, 12:18 pm »
More than likely it will eventually stop - but in the mean time it will drive you crazy as it will work for a bit, then stop, then start, then......
Send it to Dan and they will take care of you.
When my player was at Dan's, I had my laser replaced even though I had no issues.  This essentially set the laser clock back to zero for me.  And I still have my old one just in case.
modwright
    • ModWright Instruments
« Reply #10 on: 5 Jun 2012, 04:23 am »
No problem replacing the laser.  Flat $150 + return shipping charge.
Should solve the problem.
Dan
