HT Bypass in SWLP 9.0SE/LS 100
0 Members and 1 Guest are viewing this topic. Read 2448 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« on: 26 May 2012, 04:29 pm »
New to this function........  does the preamp need to be powered on in order to use HT Bypass?  Ideally, powered off would allow bypass and powered on would engage preamp.  Don't know if this is technically or sonically feasible, but it seems like a waste of tube life if the former.
Enlightenment?
Thxs,      .............Peter
ted_b
Re: HT Bypass in SWLP 9.0SE/LS 100
« Reply #1 on: 26 May 2012, 04:45 pm »
HT bypass is selectable when powered off, yes.
vintagebob
« Reply #2 on: 26 May 2012, 04:50 pm »
ted_b
« Reply #3 on: 26 May 2012, 05:05 pm »
Oops, my bad.  On the 36.5 it was either.  Sorry.
pstrisik
« Reply #4 on: 26 May 2012, 06:02 pm »
Thanks everyone.  Not the answer I was hoping for though.  Interesting that the higher end preamp can do this but the 9.0 and 100 can't.  Wonder if it is a design/cost issue.
........Peter
Charles Xavier
« Reply #5 on: 26 May 2012, 10:04 pm »
........Peter
I'm pretty sure the 9.0 doesn't need to be powered on . Dan will chime in soon .
SoCalWJS
« Reply #6 on: 26 May 2012, 10:07 pm »
The LS100 needs to be on for HT bypass.
http://www.audiocircle.com/index.php?topic=81252.msg858216#msg858216
+1 from an owner who has it hooked up for HT bypass.  :green:
dminches
« Reply #7 on: 26 May 2012, 10:12 pm »
+2. The LS-100 needs to be turned on.  Dan mentions it in one of these theads.
pstrisik
« Reply #8 on: 26 May 2012, 10:15 pm »
Yes, vintagebob posted the link above.
........Peter
