Levinson 332
0 Members and 1 Guest are viewing this topic. Read 1920 times.
fridays
Levinson 332
« on: 26 May 2012, 02:52 am »
My 332 has developed a hum in the left channel Levinsons service partner  :x said it would cost $1600 to fix
should I start looking for a new amp?
songlove
Re: Levinson 332
« Reply #1 on: 26 May 2012, 04:16 am »
I have the same problem for my amp, and I just find a local hi-fi store to fix it with only 200 bucks, so I recommend you to check with local service store to see if you can get the cheaper price.
fridays
Re: Levinson 332
« Reply #2 on: 26 May 2012, 03:39 pm »
The problem is I live in bf Iowa :cry:
electricbear
Re: Levinson 332
« Reply #3 on: 26 May 2012, 05:31 pm »
the humming is not an uncommon problem with the Levinsons. I think that they charge a flat rate for repair no matter what the problem is. I once sent a monoblack to them for repair beacause it was creating a fluttering sound through the tweeter. When I got it back the problem was still there. Needless to say I wasn't impressed.
I'd try and find somewhere relatively local if you can. If you fancy a road trip or want to send it somewhere try St Louis Computronics is St Louis Mo. Jeff is really good with amps and is reasonably priced. You can get his contact details at www.stlouiscomputronics.com.
PRELUDE
Re: Levinson 332
« Reply #4 on: 26 May 2012, 07:37 pm »
I know few with ML that been very happy with this place good customer service and the highest paid was $350.They are certified to fix ML and company is ISO.Just give them a call 1-800 number.Good Luck
http://www.unitedradio.com/consumer/
roscoeiii
Re: Levinson 332
« Reply #5 on: 26 May 2012, 09:50 pm »
Brutal Fridays.
Sounds like the 300s series of ML has a lot of problems. Check out this Audiogon thread:
http://forum.audiogon.com/cgi-bin/fr.pl?aamps&1336954152&openfrom&1&4#1
 Here's hoping you can find a cheaper place for the repair.
fridays
Re: Levinson 332
« Reply #6 on: 27 May 2012, 02:30 pm »
Thanks all
I may try Bob at Audio Labs first...this sucker is heavy
