How to set up a room for great bass
0 Members and 1 Guest are viewing this topic. Read 4737 times.
medium jim
« on: 25 May 2012, 04:58 pm »
One of the most difficult things to do is getting truly great bass in difficult rooms and would appreciate those who have gone through the process to post here.   The hope is that this thread will become a reference point sticky thread.
Jim
Devil Doc
  • On the road to Perdition
Re: How to set up a room for great bass
« Reply #1 on: 25 May 2012, 05:33 pm »
I used Jim Smith's book and DVD and recommend them highly. A whole lot of fiddling around, though. especially without an RTA. Wrecked my back moving my flippin' chair and speakers around for the smoothest bass. Finally got to with-in +/- 3dB down to 31.5 Hz. I used test tones and a rat shack spl. meter. Not ideal, according to smith, but it's what I have. It was worth it but what a pain in the back.
Doc
max190
« Reply #2 on: 25 May 2012, 07:18 pm »
I wouldn't say great but I would say coherent bass...
What got me there was 1st a lot of trial and error moving my spkrs around then addressing the 3 open corners with GIK 244's, also placing 1 each on the FW center and directly behind the LP. The other corner is the entrance to the room and I leave that door open.
JohnR
« Reply #3 on: 26 May 2012, 01:31 am »
Hopefully it's OK to post links... here are links to Parts 1 and 2 of Paul Spencer's Bass Integration Guide:
http://www.hifizine.com/2011/06/bass-integration-guide-part-1/
http://www.hifizine.com/2011/09/bass-integration-guide-part-2/
(Part 3 will be published in a week or so.)
JerryM
  • Where's The Bar?
« Reply #4 on: 26 May 2012, 01:37 am »
Super cool, JohnR.  :thumb:
medium jim
How important is room treatments to acheive Bass Nirvana?
« Reply #5 on: 26 May 2012, 03:48 pm »
I just don't know and welcome those with expertise or first hand experience to share their knowledge.
Jim
kevin360
  • án sǫngr ek svelta
Re: How important is room treatments to acheive Bass Nirvana?
« Reply #6 on: 26 May 2012, 04:05 pm »
In a word, it's critical. Having said that, I must confess that I need more. It's been nearly two years since this project began (we had the lot cleared on June 21, 2010), and there's still work to be done. Another problem is that I blew my budget out of the water - the project cost me twice my initial projection (kept thinking of things to include). I can't stop fiddling with the damn system - just purchased some tubes and...
Okay, I promise to do more by summer's end. :wink:
SoCalWJS
« Reply #7 on: 26 May 2012, 04:09 pm »
I put wedges of OC703 in the front corners of my room and was happy with the results. Mellowed out a nasty dip centered at about 57 Hz, took care of a couple of smaller dips around 125-160 Hz (using Omnimic to get measurements), and helped the soundstage with regards to focus and depth.
I cut each panel into 4 triangular wedges and ended up with stacks 4 feet tall in each corner that are behind bookcases that are angled to go directly in front of the wedges and hides them from view. I would like to add tri-traps on top of these stacks that would raise the treatments all the way to the ceiling, with a finished product showing above the tops of the bookcases.
I am a firm believer in the significant improvements bass treatments make in my system.  :thumb:
kevin360
« Reply #8 on: 26 May 2012, 04:22 pm »
I used some of that same material, but I placed it behind the sheetrock when building the room. Actually, it's attached to the back of the studs and there's foam between it and the wallboard. I didn't have to worry about making it pretty, but is that location effective at all? My actual objective was trying to keep from disturbing my neighbors and I can enjoy rather substantial bass without complaint, so I accomplished that goal.
I need more trapping - I know. This is the most challenging part of an audio system to get right because the damn room is so influential.
« Last Edit: 28 May 2012, 01:13 pm by kevin360 »
Diamond Dog
« Reply #9 on: 26 May 2012, 06:13 pm »
+1. Using a combination of GIK product here and it was definitely $$$ well spent.
D.D.
medium jim
« Reply #10 on: 28 May 2012, 02:35 am »
I stumbled across this article:
http://www.ethanwiner.com/acoustics.html
Jim
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #11 on: 28 May 2012, 11:43 am »
Geddes method involves a few subs,  and, ideally, wall damping (Constrained Layer Damping) construction for optimum results.
Here is specific info and setup process adapted from Geddes recommendations
http://mehlau.net/audio/multisub_geddes/
TRADERXFAN
    • GALLERY
TRADERXFAN
    • GALLERY
« Reply #13 on: 28 May 2012, 11:50 am »
Double Bass Array
or Controlled Acoustic Bass System
Using rectangular room with specific many sub drivers positioned on walls and cancelling time delay equipment to get extremely smooth bass response. Requires that there is very little deviation from perfectly rectangular in regards to openings etc...
http://www.avsforum.com/avs-vb/showthread.php?t=837744
Can use google translate from german
http://de.wikipedia.org/wiki/Double_Bass_Array
TRADERXFAN
    • GALLERY
« Reply #14 on: 28 May 2012, 11:58 am »
http://jamesromeyn.com/home-audio-gear/dsa-1-0-distributed-subwoofer-array-5-pieces-4k-usd/
DEBRA multisub approach. Details here.
Placement method almost at end of the page.
WGH
« Reply #15 on: 28 May 2012, 01:10 pm »
There is a lot of excellent information about setting up bass speakers in a stickied link in the Acoustics Circle:
Loudspeakers, Rooms, and Subwoofers - Audiophile Articles
Floyd E. Toole, Ph.D. and Todd Welti can get very technical in some of these white papers but there is a lot of tips in between the formulas.
I add new articles as I find them, this month's addition is a white paper about designing the perfect room including sections on room proportions, background noise, reverberation time and control of early reflections.
Wayne
