Question about the Synergy Power Amplifiers
0 Members and 1 Guest are viewing this topic. Read 1454 times.
gregmav
« on: 23 May 2012, 10:56 pm »
Do the new Synergy amplifiers "double down" in power?  For example, the new Synergy 450 is rated at 225 watts per channel at 8 ohms.  When presented with a 4 ohm load does the power double to 450 watts per channel?  Just curious.
mrlittlejeans
Re: Question about the Synergy Power Amplifiers
« Reply #1 on: 24 May 2012, 12:37 am »
I asked the same question.  here was Frank's answer.
avahifi
    • http://www.avahifi.com
« Reply #2 on: 24 May 2012, 01:02 am »
The Synergy amps will essentially double power into 4 ohm loads, up to the maximum recommended 6 amp quick blow speaker fuses.
Using bigger fuses than this will blow your speakers first, saving you the cost of replacing fuses.
Frank Van Alstine
