For sale: Ming Da MC3008-AB SE
0 Members and 1 Guest are viewing this topic. Read 4076 times.
npdang
« on: 23 May 2012, 06:07 am »
I purchased this amp new in November 2011. I paid ~$1950. I have all of the original packaging. This amp is in perfect working condition and excellent cosmetic condition. I have not put more than ~100 hours on the tubes. This amp is also the "special edition" which comes with upgraded Full Music tubes. This amp also functions as a pre-amp with multiple inputs and a solid aluminum remote control.  I am asking $900.
This is a great sounding amp and a real bargain for someone looking for a high powered SET sound. This amp is not syrupy at all, rather the sound is typical of a good 805 based SET amp with an easy, relaxed, and warm tone. Bass is incredibly deep and strong. Images, especially lead vocals and instruments are huge with plenty of depth and layering. I feel that the strongest point of this amp is that it has huge presence and excellent depth. Tonality falls on the rich and relaxed side, and is a perfect match for jazz and vocals. Top end is very relaxed, never sounding harsh or strident although it is a bit sweeter than dead neutral. I would say it compares very well with the Cary 805 which I have also owned. For what I paid, I thought it was a considerable bargain. For what I'm asking, it is an absolute steal, especially if you are looking to try a high powered SET on a budget. I just bought new speakers and I needed a new amp as well, otherwise I would not consider selling it. This amp drove my 85dbwm Usher Mini Dancer 1's with good authority and dynamics.  Local pickup welcome in Orange County, CA.
My Ebay Feedback:
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=npdang&&_trksid=p4340.l2560&iid=200769656227&sspagename=VIP:feedback&ftab=FeedbackAsSeller
Manufacturer info:
Serious upgrade to the famous MC3008-AB
Improvement implementation has taken over 1 year
Great achievement in higher S/N ratio
New sophisticated circuit redesign for ultimate working stability
Full Music 300B x 2 used in this new edition
Special made high end 805BSE vacuum tubes for output session
Remote control function added
Special odm power output meter added
Single Ended Class A integrated amplifier
Heavy weight Stainless steel and alloy plate construction
Custom built audio and power transformers
Zll and H18 long grain annealed and directed steel sheets
Hand built with alll hand welding internal connections
USA made Teflon silver cable for audio signal paths
High-end capacitors, USA made resistors
High class ALPS volume control from Japan
Gold plated speaker out terminals
Crystal transparency coupled with delicate 300B fantasy
Beautiful 3 dimensional sound stage with stunning dynamics
Detachable power cord system (IEC)
TECHNICAL:
Output Power: 40W x 2 Class A
Input Impedance: 100kohms
Output Load Impedance: 4ohms, 8ohms
Input Sensitivity: 350mV
Frequency Response: 18 Hz - 35 kHz, +/-1%
Vacuum Tubes: 805BSE x 2, Full Music 300B x 2, ECC82 x 2, ECC83 x 2
THD+N: ≤ 1 %
S/N ratio: ≥ 93db
Dimensions (L x W x H): 44 x 36 x 26 cm
« Last Edit: 11 Jun 2012, 11:30 pm by npdang »
Re: For sale: Ming Da MC3008-AB SE
« Reply #1 on: 23 May 2012, 07:11 am »
Wow gorgeous tubes, 12AX7 and 805 are a great sound marriage. :thumb:
npdang
« Reply #2 on: 12 Jun 2012, 01:20 am »
Bump  :D
saisunil
« Reply #3 on: 12 Jun 2012, 03:05 am »
I want this amp - just for looks alone ;-)
npdang
« Reply #4 on: 12 Jun 2012, 03:10 am »
Sold, thanks Sunil.
