Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
VinylFlat - has anyone tried one?
0 Members and 1 Guest are viewing this topic. Read 1353 times.
J-Pak
22 May 2012, 03:43 pm »
VinylFlat seems to be getting positive reviews on various audio forums as well as a favorable review from Stereophile.
I'm mostly interested in using the oven method since I've heard a few reports of the AC adapter power supplies dieing on the pouch.
Has anyone tried one?
vinyl_guy
Philippians 4:6-8
Re: VinylFlat - has anyone tried one?
22 May 2012, 03:52 pm »
There is an existing thread on the Vinyl Flat,
http://www.audiocircle.com/index.php?topic=96501.0
I use the pouch with very good results. I have not heard of any problems with the AC adapter and given how helpful the guys who invented and sell this are, I would think they would replace it.
TONEPUB
Industry Participant
Reply #2 on:
22 May 2012, 04:11 pm »
I've had good luck with it, though as you may have seen from the Stereophile article, careful monitoring of oven temperature is critical.
roscoeiii
Reply #3 on:
22 May 2012, 04:59 pm »
Yes, a separate oven thermometer seems key. At the temps that the VinylFlat operates, DO NOT trust your oven dial.
vinyl_guy
Philippians 4:6-8
Reply #4 on:
22 May 2012, 05:13 pm »
A lot of ovens, both old and new, do not have setting as low as 150 degrees.
J-Pak
Reply #5 on:
23 May 2012, 11:27 pm »
Oops, I was just using ctrl+f to search vinylflat. Thread can be closed
The Vinyl Circle
woodsyi
