Help Supersize Image
0 Members and 1 Guest are viewing this topic. Read 1095 times.
ZLS
« on: 21 May 2012, 11:54 pm »
    Some young children were banging on a friends keyboard, and now all the images are super sized!
How can they restore a normal image?
                                                          Thank You
Æ
Re: Help Supersize Image
« Reply #1 on: 22 May 2012, 12:24 am »
More information, details would be helpful.
Only images such as pictures (iPhoto)?
A Browser (Safari) related issue?
Or everything on the entire viewing screen regardless of what you are looking at?
If everything on the screen, then;
1. One click on the Apple in upper left corner.
2. One click on System Preferences.
3. One click on Displays.
4. Select the Resolution you prefer.
mnilan
« Reply #2 on: 23 May 2012, 05:44 pm »
ZLS:
They may have just zoomed the screen.  If so, then all you have to do is put the cursor in the window that is zoomed and double tap your cursor pad with two fingers.  Good luck.
