0 Members and 1 Guest are viewing this topic. Read 3159 times.
And on the other side, of course, there is the Mac mini... To OP, it sounds like you have a very small room? Perhaps reconsider the screen idea and look into "headless" options.Another solution is to put the computer in another room and run wires through the wall or floor. Brute force but effective...
"Headless" is where the computer doesn't have a screen and keyboard, but is controlled over the network from software running on a phone, tablet, or laptop. I don't know what the Windows (or Linux) options are, but the Discless Circle would be the place to ask...
If I have my amps in the center and sacrifice a bit of my closet-turned-into-bass-trap for the computer, that would mean a 20' interconnect running from the computer to the preamp. Even if I put the DAC midway, which might look funny, that's still a long way. Thoughts?
Haha, most of the models I've used are so noisy! ... Does anyone else use a computer, laptop or desktop or HTPC for this purpose, exclusively for music playback? What type do you have, and how do you keep it quiet?
