Audio/Video Gear and Systems
The HiRez Music Circle
ted_b
HiRez Mixtapes - possible?
0 Members and 1 Guest are viewing this topic. Read 971 times.
Without music, life would be a mistake.
18 May 2012, 06:28 pm »
Hi all,
I have a bunch of SACD's and other hirez that I've ripped using the ps3. I have a question - if I want to put together a demo tape of tracks from different SACD's onto a single disc, how would I go about doing that?
Russtafarian
Typical reaction to the music I play
Re: HiRez Mixtapes - possible?
18 May 2012, 08:21 pm »
I've been thinking about the same thing. I'm guessing it depends on the player you want to play the disc on. I know of four options:
DVD-V: Compatible with any DVD player. Convert files to 24/96 PCM and burn tracks to the audio portion of the DVD-V disc format
DVD-A: Compatible with DVD-Audio players. Convert files to 24 bit PCM up to 192 and burn tracks to DVD-A disc format
DSD Disc: Compatible with select SACD players. Assemble DFF tracks in Korg AudioGate and burn to DSD Disc format.
CD: Universally compatible. Assemble tracks in Korg AudioGate, convert to 16/44 and burn to CD
Are there any other disc formats for music playback I missed (other than MP3)?
Russ
ted_b
