FS: DIY MTM Towers ER18'S designed by Dennis Murphy & P. Kittinger LOWER $450
0 Members and 1 Guest are viewing this topic. Read 4173 times.
lhunsic105
NOW $450 AND i CAN SHIP.......................2 BOX'S 69 LB EACH
  I have a Pair of ER18's that was designed by Dennis Murphy with the Mass Loaded Transmission Line Enclosure designed by Paul Kittinnger.  This DIY design  bears a very strong family resemblance to both the Salk SongTower and its big brother the Salk HT2-TL. The woofer and tweeter choice and the crossover design of the speaker is the work of Dennis Murphy who designed many of the Salk products including the SongTower and the HT2-TL. Paul Kittinger designed the mass-loaded transmission line (MLTL) cabinet for this new speaker, using the same method as he used for those two very successful Salk models.
The  differences between this  design and the Salk speakers are the drivers and the DIY cabinet. The woofers are  the SEAS,  ER18RNX  an 18 cm (7") woofer with a paper cone doped with reed fibers (Two per speaker) and the Tweeter which  is the Fountek NeoCD3-v2 ribbon tweeter.  The cabinet has internal dimensions 7½" wide × 12" deep × 43" tall,  3/4” thick. The port tube is 3" diameter × 2¾" long and the cabinet is stuffed with 17-18 ounces of polyester fiberfill confined to the upper 22" of the interior. With two ER18 woofers, it is predicted to have a F3 of 35 Hz.
I would rate the speaker a 6  due to the DIY and the cabinet finish which is just black painted.  Cabinets are solid but finish is a bit rough but is presentable.  Built to spec with quality crossover parts including Clarity SA Caps in Tweeter Circuit. Parts cost over $650  without cabinets.  Selling for $495 pick up in Asheville, NC 28806.   Please e mail me at [email protected]
I have  pics I can send.  Speakers are in perfect operational condition and sound excellent!!  IMO one of the better box speakers I have heard.  My referance speakers are Soundlab Electrostatic M-3 with the PX membranes.
« Last Edit: 22 May 2012, 02:16 am by lhunsic105 »
jackman
You should post a picture.   Dennis designs some great sounding speakers and you will have a better chance of selling it if you post a picture.  Best of luck to you.
J
lhunsic105
I would post some pics but I am having a hard time getting them to up load.
randytsuch
You might have to resize them to a smaller file, lower resolution.
Randy
