0 Members and 1 Guest are viewing this topic. Read 4189 times.
I'm not sure if this is posted in the right place or has already been posted elsewhere.Interesting listen if you have some time to kill.http://www.sciencefriday.com/segment/02/10/2012/why-vinyl-sounds-better-than-cd-or-not.htmlI'll take the vinyl, myself.
I just clicked on it a second ago and it opened. I'm not sure why your computer is giving you a problem.
The answer is 90% in the mastering... LP's and CD's are mastered seperately and differently.I can record an LP, and play back the digital version - level matched with the original... neither I nor my other half can tell which one is which in a blind switch test.(Mind you with my previous recording hardware, the difference was clear, so it also depends on the quality of the recording chain!)In any case that indicates that the problem is unrelated to the actual medium and rather is to do with the mastering of the recording.And yes I usually prefer the vinyl version.Another thing - cartridges are an inherently flawed reproduction system (as are speakers) - and they impose a range of distortions and non-linearities.... some people have their system set up to where they particularly enjoy those euphonic flaws. - In which case they will prefer the LP to the CD in almost all cases - effectively the Turntable is also being used as an equaliser!Others have the system set up for total neutrality - in which case it will almost always come down to the mastering quality on the two recordings.I have yet to listen to that link (looking forward to it... I have great respect for Sean Olive)bye for nowDavid
You are absolutely right. I've heard fantastic and terrible masterings on each format. There is no guarantee....
Yes well recorded digital is superior, and yes double blind tests confirm it, and yes LP's frequently sound better than re-mastered digital versions... sigh.David
