Simaudio MOON LP3 Phono Preamp/ Black - SOLD-
0 Members and 1 Guest are viewing this topic. Read 2406 times.
Stercom
« on: 12 May 2012, 02:06 am »
This is an excellent phono preamp that performs well above its low price! -SOLD- (retail is $500) This unit has received excellent reviews. Here is some info from the Simaudio website:
· End-user adjustable impedance loading (100Ω and 47kΩ) · End-user adjustable capacitance loading (0pF and 100pF) · End-user adjustable gain for moving magnet (40dB) & moving coil cartridges (60dB) · Two-layer PCB tracings using pure copper for low impedance characteristics. The advantages include better circuit layouts resulting in a much shorter signal path and a vastly improved signal-to-noise ratio · Inductive DC Filtering for a significantly lower noise floor · Accurate matching of military-grade components with ultra-tight tolerances using surface-mount technology for extremely short signal paths · Compact, rigid all-aluminum chassis with gold-plated RCA connectors.
« Last Edit: 22 May 2012, 05:27 am by Stercom »
starkiller
Re: Simaudio MOON LP3 Phono Preamp/ Black - $275
« Reply #1 on: 12 May 2012, 03:40 am »
Very very tempting! Partial trades perhaps.. :scratch:
Stercom
« Reply #2 on: 12 May 2012, 05:04 am »
No trades at this point. If it sits for awhile then perhaps. Thanks.
starkiller
« Reply #3 on: 12 May 2012, 11:37 pm »
Ok,will  see what i can do..
Stercom
« Reply #4 on: 18 May 2012, 05:14 am »
« Last Edit: 22 May 2012, 05:28 am by Stercom »
