record weight or record clamp which is more effective
0 Members and 1 Guest are viewing this topic. Read 10911 times.
mgsboedmisodpc2
Re: record weight or record clamp which is more effective
« Reply #20 on: 13 May 2012, 08:00 pm »
I am quoting various sources over the web.
Thread Killer
"An oversized acrylic platter is used with a bubbly vinyl coated foam plastic mat"
threadkiller
« Reply #21 on: 13 May 2012, 08:14 pm »
Okeedokee, whatev...
Now that you're talking Classic go right ahead.... You kept typing WTA earlier.
Do not infere that they are one and the same. :)
mgsboedmisodpc2
« Reply #22 on: 13 May 2012, 08:22 pm »
WTC WTA are different.
One was designed for a clamp
the other was not
Why
so anyone try a clamp on a WTA with good or adverse resluts?
mick wolfe
« Reply #23 on: 14 May 2012, 03:35 pm »
the other was not
Why
This subject has also been thoroughly covered here in the "which would you choose" thread. Bottom line.....both the designer of the WTA and the distributor do not recommend the use of any clamp on the WTA. It's simply a different animal as opposed to earlier designs. They've done the legwork for you. Forget the clamp and just enjoy the music.
