Just Bought a DPS
0 Members and 1 Guest are viewing this topic. Read 2655 times.
Erocka2000
Just Bought a DPS
« on: 9 May 2012, 07:16 pm »
I'm going to pick it up after work.  Any do's and don'ts I should know before hooking it up?
Shakeydeal
Re: Just Bought a DPS
« Reply #1 on: 9 May 2012, 10:38 pm »
Check your TT speed after you get it running. Mine was fast.
Shakey
Erocka2000
« Reply #2 on: 10 May 2012, 01:52 pm »
After a night of listening, I have to say, that the DPS does offer a noticeable improvement.  I was skeptical before purchasing, but now I'm glad I did.  The best way to describe the improvement, is if any of you ever had a Rega turntable and if you replaced the stock subplatter with a Groovetracer reference subplatter (or some other machined subplatter).  Every thing became more focused and crisp.  Vocals are spot on and imaging seems more accurate.  I did have to adjust the speed after adding the DPS, but everything is on point.
I definitely recommend the DPS.
roscoeiii
« Reply #3 on: 10 May 2012, 02:27 pm »
I do agree it is a fabulous addition to the WTA.
« Last Edit: 10 May 2012, 07:25 pm by roscoeiii »
Erocka2000
« Reply #4 on: 10 May 2012, 03:18 pm »
Wow, Roscoeii, I'm guessing the Townshend won out.  It must be a fine deck.
roscoeiii
« Reply #5 on: 10 May 2012, 03:20 pm »
Both are very very fine turntables. It came down to being able to take some money out of my system by selling the WTA. I could certainly see returning to the WTA in the future. It was a sad farewell, with Kieth Jarrett soaring on the piano in a way that will be missed.
Shakeydeal
« Reply #6 on: 10 May 2012, 07:19 pm »
Well I didn't pay tax or shipping on mine, so your best bet will probably be to send it back.
Shakey
roscoeiii
« Reply #7 on: 10 May 2012, 07:26 pm »
Yeah, shipping mine back since I no longer have the WTA. Does make a nice difference, for sure. Well worth checking out.
threadkiller
« Reply #8 on: 11 May 2012, 04:37 pm »
Well, take care, Rosco.  I'm sure we'll see you on another forum. :thumb:
roscoeiii
« Reply #9 on: 11 May 2012, 04:52 pm »
Oh don't you worry, I will still be following WTA threads.
