Audio/Video Gear and Systems
Cheap and Cheerful HiFi
Letitroll98
Cheap USB to Coax alternatives
0 Members and 1 Guest are viewing this topic. Read 2958 times.
Noseyears
Restricted
SS-Audio
4 May 2012, 06:52 pm »
A couple of interesting alternatives on the cheap side,
Ha Info U2
And this one, (Diy)
http://www.minidsp.com/products/ministreamer
If you guys know more options, you can add on the list.
Re: Cheap USB to Coax alternatives
4 May 2012, 08:04 pm »
Here is what I use.
ADS Tech RDX-150
Doesn't do hirez, but that doesn't matter to me at this time. I use it between my netbook and Marantz AVR. USB to Toslink.
gooberdude
Reply #2 on:
5 May 2012, 12:15 am »
I've had the $99 Consonance converter for a few months now, definitely an improvement. Available thru grant fidelity.
no affiliation
Noseyears
Restricted
SS-Audio
Reply #3 on:
22 Jun 2012, 05:50 pm »
The Musical Fidelity V-LINK can be found for around $80 on ebay, its also a nice solution for PC users with limited bandwidth (Via USB) on their Dac's.
boynamedsue
Reply #4 on:
22 Jun 2012, 05:54 pm »
The new version of the audio-gd digital interfance is pretty good, and I believe is async. The price ranges from $108 to $198 depending on options. Impressions can be found on the audio-gd DI on headfi.
Noseyears
Restricted
SS-Audio
Reply #5 on:
27 Jun 2012, 12:57 am »
A small and nice looking converter from matrix electronics (chinese i think)
http://www.matrixelectronics.net/matrix-24-bit-96-khz-usb-to-coaxial-converter-p-197.html
Letitroll98
