For Sale Bryston 6B Monoblock Amp
0 Members and 1 Guest are viewing this topic. Read 1301 times.
Gypsy
« on: 3 May 2012, 03:13 pm »
I have a rare Bryston 6B Monoblock amplifier in very good condition up for grabs.
The specs are as follows
Rated distortion: less than .02% I.M.
or THD from 20-20 KHz at rated power or below.
Rated power:
500 watts 8 ohms
800 watts 4 ohms
500 watts 2 ohms
800 watts 1 ohm
6400 cm2 of heat sinking, etc.
19" X 5.25" X 13.5", 50 lbs.
From the general specifications from all amplifiers:
Noise 100db below full output
Crosstalk - below noise 20 to 20 KHz
Slewing rate greater than 60 volts per microsecond
Power bandwidth less than 1 Hz to over 100 Hz
Damping factor over 500 at 20 Hz, ref. 8 ohms
$800 or Best offer
Item is located in Ottawa Ontario Canada and shipping is the buyers responsibility
Will ship fully insured through UPS with tracking number
Can ship out of NY as I go down there often to save the buyer some $$
Item weighs 50lbs
please contact me directly at [email protected]
« Last Edit: 3 May 2012, 05:02 pm by Gypsy »
