Suggestions for high quality & durable External CD/DVD player/burner.
0 Members and 1 Guest are viewing this topic. Read 1039 times.
fado
This unit would be primarily for ripping CD's to digital storage. I do not need Blu-ray but don't care if it is included with an otherwise high quality unit.
Since USB 3.0 is becoming more prevalent, I would prefer one that includes USB 3.0 but have no idea how it impacts sound quality.
I will be building or purchasing a new PC soon so I can be sure USB 3.0 or other connections are included.
Thank You
whell
For what it's worth, the speed offered by a USB 2 connection is should be plenty fast enough for ripping CD's.  You don't want to read the CD's at blazing speeds for ripping purposes, and quality ripping software like EAC takes its time with a rip anyway, so the extra speed of USB 3 doesn't work to your advantage for ripping.  You might get away with a low cost unit (heck, even a used one of funds are an issue), particularly if the unit's services won't be required once you're done ripping your collection.
fado
Thank You for the response.
