Aragon8008 dual mono amp 200/400 WPC asking $799 ( 7-8 rating) Quick SOLD!!
0 Members and 1 Guest are viewing this topic. Read 2326 times.
bbchem
STEREOPHILE CLASS B! QUOTE BELOW>> $2200 ORIGINALLY, 200/400 WPC 8/4 OHMS  ASKING>> $799 PLUS SHIPPING 70LBS FROM 34759>> FREE PAYPAL
Photos show dust no scratches
[email protected] or PM  100% Audiogon and Ebay!
Like most audiophiles, I salivate over the latest Jurassic, second-mortgage-inducing power amplifier. Whether it's about the music itself, or simply "my amp is bigger than your amp" one-upmanship, we all know that those who risk a hernia in pursuit of the ultimate in sound invariably come out winners.
Or do they? There are many superb-sounding super-amps, to be sure, but once you reach a certain point, the cost/weight ratio begins to spiral upward much faster than the sound quality. Increase the size and weight of anything, and the manufacturing costs—and retail price—inevitably increase. Increase the final price, and you have to increase the size and weight to retain a high perceived value. And on and on. The cycle ends only when the manufacturer judges that the market for the product can no longer justify a higher price.
But there is another way. Mondial Designs was not the first company to realize that they could prosper with a Build it Good, Make it Affordable and They Will Come attitude. But from the beginning, they built on that foundation, and are still one of the best at making the concept work in a marketplace that goes ga-ga over big and expensive. The truth, of course, is that more people can afford—and accommodate—a $2000, 70 lb amplifier than a $10,000, 200 lb one. But can the smaller amp compete sonically? The original Mondial design, the Aragon 4004, proved that it could, and the follow-up to that design, the 4004 Mk.II, built on that initial success (footnote 1). The subject of this review is the new 8008, which is a significant refinement of that earlier model.
Eight double-o eight
The Aragon 8008 is manufactured by the same Connecticut-based facility which built the earlier Aragon amplifiers, a factory which also manufactures industrial, medical, and military components. The 8008's heatsinks are significantly larger than those in the 4004, and now form a basic structural element in the redesigned chassis. The changes are visibly evident in the reconfigured ventilation slot (the "V" slot above the internal heatsinks which has become an Aragon trademark) and the front panel. The cosmetic alterations are subtle at first glance, but they give the new amplifier a more substantial appearance compared with the 4004.
The new heatsinks are designed to keep the operating temperatures of each of the output devices as close to identical as possible. The 8008 runs hot in operation, even in idle, which suggests the output stage is biased well into class-A. (Like most amplifiers, it switches to class-AB at higher output powers.)
The power supply is based on a single 2000VA toroidal transformer. There are separate transformer windings for each channel, along with separate rectification and filter capacitance. The input stages are fully discrete, running in class-A, and each channel has its own circuit board for improved isolation. A new DC servo circuit allows the 8008 to operate down to 5Hz. This circuit disconnects the loudspeakers if any energy—including DC—is sensed below that frequency.
In other respects the 8008 continues the design philosophy of the 4004. The power supply is claimed to be the largest which can make full use of a domestic, 15A, 120V power line. The amplifier is designed to drive low impedance loads. Precision matching is performed on all transistors, and gold, silver, or palladium is used on all contacts. Mil-spec or medical-spec parts are used throughout, including silver-composite, Teflon-insulated wiring. All resistors are epoxy-sealed, which according to Mondial, ensures a consistent 1% tolerance in all climatic conditions.
The rear panel of the 8008 has plenty of room for the unbalanced RCA input jacks, detachable power cord, and two pairs of five-way loudspeaker binding posts (for bi-wiring, if desired). The parts quality touted for the 8008 falls down, however, with these posts; three of the eight plastic hex-heads on the review sample stripped in normal use. It was still possible to tighten down spade lugs on the stripped posts, but less snugly than with unstripped terminals.
Our 8008 sample was single-ended only, but a version with balanced inputs is available for an added $500. My experience with balanced audio gear suggests that the difference in sound can be small to nonexistent, unless you use long leads in an EMI-riddled environment. Since I was unable to compare balanced and unbalanced inputs in our sample, any opinions on the two with this design would be mere extrapolation from my prior experiences. Nevertheless, I would listen long and hard before paying the 25% premium for balanced inputs.
Sound
While I have not heard the Aragon 4004 Mk.II for two or three years, the 8008 appears ready to sustain the earlier amplifier's reputation—and then some. Its treble was full of detail both subtle and obvious—whichever was musically appropriate. In the reference system, my first reaction to the Aragon was that it produced one of the best-sounding top ends, overall, that I have heard from the Veritas v2.8—and I've tied a lot of pricey amplifiers to those loudspeakers.
_______________________________________ _
Conclusion
Even if you have the spare change in your checkbook to go out and buy that dream $10,000 amplifier without any hesitation, you should listen to the Aragon 8008. You may still buy your dream, but you might just find that the choice is not as obvious as you thought it would be. And if, like most of us, you don't have that option, you should still make the comparison. It just might make you feel a lot better about your budget and the amplifier you buy.
Description: Two-channel solid-state power amplifier. Rated power output: 200Wpc continuous into 8 ohms (23dBW), 400Wpc continuous into 4 ohms (23dBW). Rated full-power bandwidth: 5Hz-20kHz. S/N Ratio: >110dB, A-weighted. THD: 0.04%, 5Hz-20kHz, at full power into 8 ohms. Slew rate: >120V/µs. Damping factor: >450, equivalent to an output impedance below 0.018 ohms. Input impedance: 22k ohms. Input sensitivity: 1.68V for full output. Power consumption: 1500W.
Dimensions: 19" W by 6.6" H by 14.6" D. Weight: 67 lbs.
« Last Edit: 5 May 2012, 07:31 pm by bbchem »
bbchem
Bump for Quick sale
bbchem
simoon
SOLD
Someone got amazing amp for an equally amazing price.
