0 Members and 1 Guest are viewing this topic. Read 28018 times.
Well yippee... like I said, the WTA is practical-a set and forget table, no clamp, no cueing fuss. And since it makes one want to really play more records, it's functioning on a much higher plain than most tables.
what sort of distance is everyone using between the bottom of the ball and the cup? I am probably around 1/8" or 3/16".
one poor design I noticed on the WTA last night is that the extra fine tonearm cable exits the underside of the arm directly above the metal rim of the ball cup. why would they do this? the wire seems awfully close to the rim, to the point of touching it when lifting the arm. it would have been so easy to make it exit a little further back, there's so much space. wonder why they did it this way?
Probably because it doesn't matter. My wire has never come close to touching the cup. It is stiff enough that it stays suspended in air. I would imagine that if the wire is touching the cup, simply move the wire and it will stay in it's place.
You still have a fine table. Yes, having had both the Classic and Reference, the Amadeus is truly wonderful.What's still remarkable, and of great benefit to someone like yourself, is that you don't have to spend a fortune to upgrade. Before the WTA, you'd switch, in your price range, for a different flavor. You'd have to spend loads to get better sound. Now one no longer has to. To show you my knuckleheaded thinking, the only table I even aspire to is the 30k Shindo Garrard.
x1
Well, here's the story on that.As great as the WTL is, in an all Shindo system it doesn't work. It's all about the Shindo voicing.A Shindo is a Shindo is a Shindo. So, until you have the money to go all Shindo, stick with WTL. And be very wary of these reviewers, and they're out there, that mix and match. Theyre deaf!
