0 Members and 1 Guest are viewing this topic. Read 9054 times.
Dave,I don't have a second 400R. Franks site says that you can use the phase inverter on a single amp to improve imaging and triple power. My worry is: will the i.7s take the increase in power?
Thanks for all of your replies. This is from Frank's website:Using an inverter bridge to make a single stereo amplifier sound better is even easier. Run one amplifier channel from an inverted output and the other from a non-inverted output. (Here's a diagram of the connection.) This puts the two amplifier channels out of phase so that the common drain on the power supply is reduced and residual cross-talk between the channels is attenuated. Reverse one loudspeaker connection to get the channels back in phase and enjoy *MORE POWER*, better separation and improved imaging. (I added emphasis)$750 is for a SEPARATE phase inverter. It is only a $200.00 option on the new Fet Valve preamp (which I am considering purchasing).Tebejo did this with two amps. You can read about it here:http://www.audiocircle.com/index.php?topic=105167.0
I have an AVA 400R amp running my 1.7s with 400wpc@4 ohms. If I get the phase inverter option on my preamp I will run 1200wpc into them. Is this O.K. to do? Anyone else have 1.7s that they drive with high wattage?
yes, you can do this if you listen in mono...Be better to get yourself a pair of AVA U70's and use the inverter to bridge them. 60 tube watts will trump 400 SS watts any day, at least in my opinion....
I've owned 25wpc SS amps from Levinson and Luxman that were full class A with massive power supplies (i.e. more headroom) that sounded like they could play as loud as or louder than other 100wpc amps, tube and transistor.
Where do you guys keep coming up with this "tube watts" vs. "transistor watts" stuff? Watts are watts. Non class A transistor amplifiers have different distortion characteristics than a tube amp, and what you're mistaking for "tube watts" is really headroom.Bring your 60 watt tube amp over and try it next to my 300wpc Burmester amp or 200wpc Pass 200.5 monos, won't even come close. I've owned 25wpc SS amps from Levinson and Luxman that were full class A with massive power supplies (i.e. more headroom) that sounded like they could play as loud as or louder than other 100wpc amps, tube and transistor.So much boils down to power supply design and amp/speaker interface, especially with tube amplifiers.Having tried a LOT of tube amps with Magnepans (of all kinds) over the last 30 years has usually been disappointing.That doesn't mean don't try it, but don't be surprised if it doesn't rock. And these are speakers that really don't rock to begin with.
