Magnepan MMG - Can I add banana plug binding posts?
0 Members and 1 Guest are viewing this topic. Read 2538 times.
michaelkingdom
« on: 27 Apr 2012, 03:14 pm »
Magnepan MMGs - Can I add banana plug binding posts?
I'm looking for an easy way of disconnecting them. Does anyone have a solution?
NIGHTFALL1970
« Last Edit: 27 Apr 2012, 07:02 pm by NIGHTFALL1970 »
michaelkingdom
Re: Magnepan MMG - Can I add banana plug binding posts?
« Reply #2 on: 27 Apr 2012, 04:52 pm »
Would you know which you used and how you attached them?
josh358
« Reply #3 on: 27 Apr 2012, 09:30 pm »
I use the same double bananas he does, one in red and one in black. They plug right in, they don't need five-way binding posts because the connectors that come on the speakers are designed to accept them as is.
tberd
« Reply #4 on: 26 Aug 2012, 03:17 pm »
 If you're looking for sound quality ditch the nanner plugs. If your speakers are Cerwin Vega like party toaters then plug away.
tberd
