SP1.7 120 deg F is it hot
0 Members and 1 Guest are viewing this topic. Read 2721 times.
Levi
« on: 21 May 2004, 04:57 am »
My SP1.7 runs 112-120F is this normal?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 21 May 2004, 06:56 pm »
Hi Levi,
Yes - the temperature is normal - you have placed the gauge over the heatsink in the SP1.7- you will notice that the temperature decreases quickly as you move to the right of that particular spot.
james
ec
« Reply #2 on: 21 May 2004, 09:08 pm »
Levi,
At one time, I had next to no air space between the top of the SP 1.7 and the top shelf.  After a 2 hr movie, the lack of ventilation would make the volume button untouchable to most.  I learned my lesson and dropped the shelf the SP 1.7 was on and now there is a good 2-3" above the unit.  All is well now.  If you look at the top of unit you will see a set of screws that run from front to back right about where your thermostat is.  These screws directly bolt the top cover to a heat sink.
Levi
« Reply #3 on: 22 May 2004, 02:19 am »
As long as you say it's normal.  I have no worries. :D
« Reply #4 on: 22 May 2004, 06:18 pm »
Hi levi,
There are 2 very large transformers in the SP1.7 on the left side ( 1 for Digital and 1 for Analog) and they put out a lot of current so the heatsink can get quite hot under drive conditions.
james
Levi
« Reply #5 on: 15 Jun 2004, 02:04 am »
I moved the temp gauge to the right close to the volume knob.  The temp goes down @9 degrees cooler.
