0 Members and 1 Guest are viewing this topic. Read 240010 times.
Have you tried turning off the clip limiter function? Just saw a review on Amazon from a guy saying it made quite a difference in sound quality.
Amazon now has the 1500 for $325. And please, I do not work for or own Amazon.I just love all of these Audiophiles that just knows how an amp sounds by just looking at the specs.
They use a cowardly mid-band 1khz rating. The amp doesn't sit on 2ohms 20hz. It's done to conceal the true power nature of that amp. Who cares about 2ohm distortion when your amp ain't powering it or can't. If you properly tested that amp in 2ohms that thing would flop around and die. It would go into protection. You want that little power supply to run and hide too, since the bass roll-off will save your distortion rating at frequencies 8ohms and higher. Don't try to align this amps power to any thing Bryston gets or states.You clearly don't know what you are talking about.
In college I knew this girl who had amazing specs, Hugh Hefner would have taken notice, then she opened her mouth and...
How long did the marriage last ..........
Think you are getting wrapped up in semantics
9 yrs of good Specs .......
Towards the end the specs began to sag and performance was intermittent. Finally it wouldn't turn on , so I traded for a newer and more up to date model! The sound is so much clearer with more of an emotional attachment.
That's what a flash converter and a digital pulse width converter is: It's DIGITAL.
You guys are great! Too bad there's not a tour for that!
That's the modulation scheme. The input signal is not converted to digital.
