SOLD: Opera Diva Callas Floorstanders (Scanspeak Revelator)
0 Members and 1 Guest are viewing this topic. Read 7859 times.
srb
For sale is a pair of Opera Diva Callas floorstanding speakers in ribbon Mahogany from Opera's top of the line Callas series.  These awesome speakers have fine Italian crafstmanship and are accurate, smooth and musical.  $2700 (MSRP $6495)
Each speaker has two 6" Scanspeak Revelator woofers, a 1" Scanspeak silk dome tweeter and a 1" rear facing ambience dome tweeter.
The curved side cabinets are built from of a combination of plywood and MDF and are veneered in beautiful ribbon mahogany with solid mahogany tops.  The front baffles are completely covered in black textured leather.  The bases are finished in satin black, and the enclosure is slightly raised above them and tilted back several degrees.
The cabinets taper into a narrow satin black rear baffle with a bottom port.  There are three pairs of large easy-to-tighten gold-plated all-metal binding posts - one pair for the woofers, one pair for the tweeter, and the third pair for the rear facing ambience tweeter.  If the rear ambience tweeter is not desired for a particular installation, that pair of posts' jumpers can be removed.
I would conservatively rate them 7/10.
SPECIFICATIONS:
Impedance:  4 ohm nominal / 3.5 ohm minimum
Sensitivity:  89dB @ 1 watt/1 meter
Frequency Response:  35Hz - 30KHz
Dimensions:  41.3"H x 7.9"W x 16"D  (~10"W x 17"D base)
Net Weight:  68 lbs.
I have the original full-size tailor-fit soft cotton protective bags and the original double box factory cartons with semi-elastic resilient foam inserts (not brittle styrofoam). The included grilles are in good condition.
« Last Edit: 15 May 2012, 05:29 am by srb »
srb
Re: FS: Opera Diva Callas Floorstanders (Scanspeak Revelator)
« Reply #1 on: 3 May 2012, 06:02 pm »
Bump  :cyclops:
srb
« Reply #2 on: 12 May 2012, 12:18 am »
Bump   :!:
