0 Members and 1 Guest are viewing this topic. Read 19813 times.
I have two JL110 subs crossed over at about 35hz with a month old pair of 3.7's. I'm with Tonepub, it really puts some kick in the low end. The JL's have enough controls so you can tweak to your hearts content.
Do you find that the JL has an effect on the definition of the 3.7's bass above the crossover point?
Hi Josh,I had the 1.7's before upgrading to the 3.7's which are less than a month old. I felt the 1.7's really need help in the low end. I also found for me in my room anyway, that the JL's called more attension to themselves when cut over above 40HZ.~Mike
Agree that it's often good to take a load off the main speaker's woofer. The problem with planars and stats is that adding a sub often (some say always) colors the sound, because the dynamic woofer has a very different sonic quality, the radiation pattern is different, and dipoles excite fewer room modes than omnis. So that's what I was wondering about, I might try someday to put a sub on my Tympanis, they start to roll off at about 30 Hz. Maybe I'll try it with the Martin-Logan sub I got for my MMG's, it's not big enough to add anything substantial to my Tympanis but I could get a sense if I could add it without causing more harm than good, crossed over at either 30 or 40 Hz (I've heard that the Tympanis benefit from the slightly higher crossover, for the reasons you mentioned).
Hi Bill,To answer your question, I was following suggestions from Barry Diament of Soundkeepers.com. I ran across a thread on the Computer Audiophile forum of all places titled “Magnepan 3.7: I give up”. The thread is very lengthy but covers a lot of area. Barry suggested letting the Maggies do what they do best in the 40HZ and above range and cut the subs in well below so they don’t call attention to themselves. My JL’s have a 12db or 24db slope and I have chosen the 12db. My preamp, the McIntosh C2300 has three different preamp outs. So I have one set going to my MC601 mono amps driving the Magnepan 3.7’s while another set of balanced outputs are going to the mono balanced input of each JL110 sub. My biggest problem was too much bass and I had to keep dialing back the subs as it was over powering my room. Also for me the JL’s blend better and do not call attention to themselves when cut in at the lower frequency. My room size is 20’ by 18’ and it is my living room, not ideal as I have to move furniture around if I want to move the Magnepan’s out 4 to 5 foot from the front wall. I do feel that my subs add a lot of spatial information to the music not to mention low end. I have Brian Bromberg’s CD Wood in which he plays an acoustic upright bass. When the subs are on, I have a much better feeling of the acoustic space that the recording was made in. ~Mike
you can build dipole subs, or buy them built, or buy four subs and run them back-to-back in pairs, w/the rear-facing subs out of phase, for dipole radiation pattern.check out the build of the sub portion of the gr research super-v...http://gr-research.com/super-v.aspxas the complete speaker kit (w/o cabinets) retails for $2500; i am certain you can build a pair of the dipole subs (or have them built for you) for less than the cost of a pair of jl110 fathoms. probably for even less than the price of a single fathom 110. four 12" servo drivers, configured in dipole pairs, w/servo amplification prowided...doug s.
Thanks, I've looked at dipole subs, both the plans on the Linkwitz site and the GR Research ones. I think they'd be excellent for the smaller Maggies. Davey built a pair for his MMG's. I'm not sure that they're the best choice for crossing at 30 Hz, though. At that frequency, you should be below the lowest non-trivial room mode in almost any room, so you lose that advantage of dipoles. The radiation pattern wouldn't be right, but for single-person listening that probably doesn't matter. And you have the output advantage of an enclosure. On the other hand, I'd have enclosure resonances. In my current room, an IB arrangement might be even better, I have an attic above me so I don't have to worry about the backwave.My main concern/question is over tonal consistency and contamination of the midbass. A high-slope digital crossover could potentially ameliorate that without introducing group delay.
While there is a lot of useful technical information being brought to the table here, much is a much to do about nothing. Bass is for the most part omni-directional and while it does radiate differently from conventional dynamic type speakers, proper integration is acheivable to the point where it is seamless. It may take trial and error to get it right, the reward is well worth it. Simply put, if you can identify the bass from the panels, adjust the gain on the bass amp(s) down, or relocate the sub(s), or adjust the phase or a combination of all three. One fault of Dipole bass is that the speakers to too high in the spectrum, bass is best on the ground as this eliminates the smear with the planars, as well as, creates a better room energy and soundstage. In my setup, I have the subs behind the panels and a couple feet to the outside and right on the wall. I have the subs set at 80hz (bottom 2 octaves) and you cannot tell where the panels end and the subs begin even when there is complicated musical passages with both uppper mid bass and with lower registers. Jim
