SOLD Acoustic Elegance Dipole 12 one of the best open baffle mid bass drivers
0 Members and 1 Guest are viewing this topic. Read 852 times.
hum4god
Hi
i am selling a pair of Acoustic Elegance TD 12 Dipole . these are the same drivers used in the granada speaker where they are paired w/ feastrex drivers:
http://www.lotusgroupusa.com/Granada.htm
they are in good condition , never abused . at this time i don't think they are available from John as he still works on his back log. or it would take 6 months to get them.
SOLD    for the pair plus shipping. i prefer usps money order , paypal adds fees. i have perfect feedback on audiogon under the same moniker.
The Dipole12 was designed specifically for open baffle/dipole use. As open baffles typically require high excursion from the drivers, this driver features a large underhung motor with full copper sleeve on the pole. This combination means extreme linearity and extremely low distortion during high excursion use. The high Q and low Fs allows for the driver itself to be very efficient at low frequencies and have a very flat response down into the mid 20Hz range. This means no EQ is required to flatten the driver itself, only to compensate for the baffle rolloff. As with all of the TD drivers the Dipole12 has extremely low and linear inductance allowing it to play cleanly up into the midrange frequencies as high as 2KHz.
Due to the underhung motor design the power handling is lower than the other TD drivers. However, these drivers were intended to be used in multiples per channel when extreme SPLs are required meaning the power handling is right where it is needed. Due to the extremely linear underhung motor, this driver has some of the best midrange performance of any TD woofer. Available in dual 8ohm coils only, specs are with both voice coils wired in series.
Dipole12 (8ohm coils in parallel) Fs: 25.9Hz Qms: 11 Vas: 273 L Cms: 0.7mm/N Mms: 55 g Rms: 0.81kg/s Xmax: 12mm Sd: 530cm2 Qes: .73 Re: 3.1ohm Le: 0.04mH Z: 4ohm Bl: 6.1T/m Pe: 200Watts Qts: 0.68 1WSpl: 90.1dB 2.83V: 94.3dB
Dipole12 Highlights: Designed specifically for open baffle/dipole use Underhung motor for extreme BL linearity Incredibly low inductance Very wide bandwidth, up to 2KHz
« Last Edit: 26 Apr 2012, 05:14 am by hum4god »
