0 Members and 1 Guest are viewing this topic. Read 11534 times.
The T50rp modded can be better than both and far cheaper!
They are excellent phones for the price, and have some of the attributes of the high end phones, but they don't have the same top to bottom sound. I own a pair of modified Fostex and also have HD800's and LCD-2's. While the Fostex can be really enjoyable, they are severely lacking from 300-400hz and down. That in itself is a deal breaker for everyday listening. That said, every once in a while I pull them out and enjoy them for a day, then box them back up.
I will say no, Hifiman HE-6 would be best even compared with LCD-3.He-400 or He-500 would be at lease as good as LCD-2 as well.
Your buying your preference in sound quality when you get down to it. Your pref. in comfort, fit etc.... Look first at what you've heard and liked not the price...you may find extreme comfort and quality of sound in phones that cost $100, $300 or $1000 and save yourself some cash instead of jumping right to 2K or more......
