0 Members and 1 Guest are viewing this topic. Read 3453 times.
First and most importantly, the base is only 8" wide. With a small kid, and more on the way, that's a safety concern for me. If my kid falls into one of them, it's going over.
QuoteFirst and most importantly, the base is only 8" wide. With a small kid, and more on the way, that's a safety concern for me. If my kid falls into one of them, it's going over. If this is a concern I don't think the RM-30 would ease your mind any better. My 626R's are incredibly stable granted they are atop custom built Sound Anchor's. With just blue dots attached I literally have to pry them off If I need to remove them.. the stands also weigh over 85lbs each which helps too .
Right now I'm trying out the Odyssey Lorelei. Overall, I like them but there are some things that just won't work in my room. Also, the bass is sometimes too much in my room. /quote]If you had too much bass with Loreleis, I am sure things would be even worse with RM-30. Generally speaking, big loudspeakers are for large rooms. Also it is generally held, that you will get smaller sweetspot with the loudspeakes utilizing ribbon drivers.If I were you, I would look for stand mounted speakers with cone / dome drivers.Brgds,Anton
