Anyone in central Iowa (Des Moines Metro)?
0 Members and 1 Guest are viewing this topic. Read 1185 times.
anodyne
« on: 18 Apr 2012, 07:46 pm »
I just purchased my first turntable and was wondering if there was anyone local that would be willing to help me get it dialed in.  I've done the initial setup, but I've read a ton and know it's an art to getting things right and would appreciate a leg up.
I purchased a Hanss Acoustics T-10 that comes with a full boated Origin Live OL-1 and have installed a Orotofon 2m Blue cart.  Just want to make sure I get it dialed in right.  Anyone interested in setting a vinyl newbie on the right path?
Afterimage
Re: Anyone in central Iowa (Des Moines Metro)?
« Reply #1 on: 18 Apr 2012, 11:22 pm »
I am in West Des Moines.  I can't help, I have gone digital, but maybe if you called the guys at Audio Video Logic or Audio Labs, they can come out and help.  I'm sure they will charge you a fee, but it might be worth it.  Good luck.
fridays
« Reply #2 on: 19 Apr 2012, 01:37 am »
I would take it to Bob at Audio Labs
anodyne
« Reply #3 on: 20 Apr 2012, 02:30 pm »
I'll have to check them out and see what the charge would be.  As usual I ended up spending more up front than I had budget and am now trying to save some money.  Besides I need the money for purchasing more records  :D
fridays
« Reply #4 on: 20 Apr 2012, 02:58 pm »
While you're down there check out the record store next door
Sorry not saving you money :)
