Why do you need the Squeezebox Touch when you can have this?
0 Members and 1 Guest are viewing this topic. Read 6737 times.
Russtafarian
  • Typical reaction to the music I play
Re: Why do you need the Squeezebox Touch when you can have this?
« Reply #20 on: 27 Apr 2012, 05:44 pm »
I found that the SB Touch analog outputs do sound very good when I connect it through a preamp or buffer stage.  It falls apart when I try to drive my amp directly from the SBT.
A relatively easy analog out mod for the Touch is to remove the surface mount coupling cap chips between the DAC output pins and the RCA jacks and replace them with wire jumpers.
