FS Furman SPR-20i Stable Power Regulator-----SOLD---------
0 Members and 1 Guest are viewing this topic. Read 1927 times.
audiogoober
SOLD
As new Furman SPR-20i. 1700 plus shipping new. Will sell for $850 shipped anywhere in the US.
Never Worry About Voltage Fluctuations Again!
For over 33 years, Furman has been a pioneer in the development of A/C power products for the most demanding audio and video professionals. Though the need for stable A/C power is nothing new, the technology inside the Furman SPR-20i  is revolutionary in its unique implementation.
Extreme AC demands require technological developments far in excess of typical home theater/audiophile power products. In your audio system, voltage fluctuations are unacceptable, at best fluctuations will cause loss of resolution and . Equipment failure or poor performance is costly. Furman’s solution is based on extensive engineering expertise, and robust build quality. The challenge of today's corrupted power lines has led to the creation of the Furman SPR-20i.
With today's chaotic demands on many municipal power facilities, A/C voltage is often reduced so that it can be stretched to fulfill excess demand. This creates a substantial negative impact on your system's performance. Power amplifiers and other components cannot perform to their full potential. Even a relatively modest reduction in A/C voltage can obliterate the sonic impact of an otherwise superior system. Just as problematic are excessively high line voltages. Excess voltage can overheat sensitive circuits; lower the life and reliability of projector lamps, and cause many circuits to shut down. With the Furman SPR-20i's exclusive Stable Power A/C Voltage Regulation Technology, voltage-starved power amplifiers and powered sub-woofers will perform at their full potential. Your entire system will be supplied with constant, virtually unwavering A/C voltage. This assures trouble-free service for any environment suffering from unstable power.
The Furman SPR-20i generates virtually no heat, and produces none of the mechanical noise typical in inferior A/C voltage regulators. Further, Furman’s technology provides virtually unlimited peak current delivery, avoiding the current limiting found in most A/C regulators.
In addition to unstable voltage, today's A/C lines are plagued with RF and EMI noise. When connecting sensitive equipment to your home's power outlet, A/C noise couples into your system's critical components. This A/C noise masks low level signals and cripples performance. This low level content is critical because it relays the crucial harmonics and ambience in audio, as well as the depth and clarity in video. With Furman's exclusive Linear Filtering Technology, televisions, projectors, DVD players, and processors are fed linearly-filtered A/C power. This dramatically reduces noise, ensuring consistent peak operation of your critical components regardless of load conditions or the time of the day.
Another critical feature is Furman’s exclusive Series Multi-Stage Protection. This virtually maintenance-free surge suppression assures the highest level of A/C protection possible, without sacrificing itself when the offending surge is severe: no damaged equipment, no service calls, and no down time! Furman’s digital A/C input voltage, output voltage, and current meters allow precise measurements of both the A/C line and the current load. These meters are a valuable asset when monitoring systems that are connected to todays potentially poor power grids, or the meters may be dimmed when monitoring is not required.
When employing the Furman SPR-20i, you will notice far clearer, stunningly focused sound and visual images from your system. Video presentation will be crisp and colors true with greater gray and black scale definition, as well as noticeably improved depth and clarity. When installed with your audio system, you will reap the dual benefits of Furman's Stable Power and Discrete Symmetrical A/C Filtering, ensuring performance without compromise — without peer.
Features
    * Provides an ultra-stable 120 VAC supply from low or high voltage sources
    * Linear Filtering Technology (LiFT) for unequaled audio/video clarity
    * Series Multi-Stage Protection (SMP) featuring Extreme Voltage Shutdown (EVS)
    * Cool running, noise free technology allows placement in critical listening environments
    * Detachable surge suppression module for telco and cable/satellite connectors
    * 20 Amp RMS Capacity
« Last Edit: 10 May 2012, 11:17 pm by audiogoober »
audiogoober
Re: FS Furman SPR-20i Stable Power Regulator
« Reply #1 on: 22 Apr 2012, 03:32 pm »
STILL AVAILABLE
ALL OFFERS CONSIDERED
audiogoober
Price lowered to $700 shipped anywhere in the US
Daedalus Audio
fwiw, this unit is my favorite power conditioner. it is what I use in my systems and at shows. this unit is especially good for tube gear. I think it is the best sounding unit Furman makes, even better than their Ref20 which goes for about $4k.
jtwrace
    • TIPP YouTube Channel
Do you have any thoughts on why?  I was looking at the Ref20 but this could be a good thing.
Daedalus Audio
the voltage regulation is the key, the Ref 20 doesn't do that.  I have had all the top Furmans and this is clearly my favorite. I do use it with an Uber buss which provides a power reserve and that is the only thing the Ref 20 does which this unit does not.  bottom line is the sound and for me this is the one.
jtwrace
Thanks!  Do you use the Uber before?
Daedalus Audio
I run the Uber first, Furman plugged into that as well as the power amps & sometimes the pre into the Buss
audiogoober
Re: FS Furman SPR-20i Stable Power Regulator-----SOLD---------
« Reply #8 on: 29 Apr 2012, 01:40 am »
SOLD!
