Scanspeak Midwoofers
0 Members and 1 Guest are viewing this topic. Read 1695 times.
Me
« on: 17 Apr 2012, 04:52 am »
Hi everyone.  The 18w/8531, 18wu/8741t, 18wu/8747t (aluminum).  Between these three drivers, which one will go lower in a sealed box?  Thanks.
Æ
Re: Scanspeak Midwoofers
« Reply #1 on: 17 Apr 2012, 06:55 am »
It kind of depends on the enclosure volume. Bigger box = deeper bass.
Go and take a look at the specs and recommendations over at Madisound and compare them for yourself.
I looked at them quickly, maybe the 18W/8531
http://www.madisoundspeakerstore.com/scanspeak-woofers-6-7/
Download WinISD or use ISD online and you can perform all the necessary calculations yourself.
http://www.linearteam.dk/default.aspx?pageid=winisd
