M2Tech Hiface with modded Mojo Audio SPDIF cable
0 Members and 1 Guest are viewing this topic. Read 2330 times.
coverto
« on: 17 Apr 2012, 12:49 am »
Here's an M2Tech Hiface with the superior BNC connector (better than RCA). Also included in the sale, but available separately for interested buyers, is the highly regarded Mojo Audio SPDIF cable, customized by the company with one end BNC and one end RCA - the optimal configuration for anybody using a Hiface to connect a computer source to an audio component.
Retail Value = $179 for the Hiface + $200 for the SPDIF cable + $25 for the modification = $404
Your price = $225 plus shipping.  8)
DETAILS
Highest quality digital audio up to 192kHz/24bit S/PDIF audio format available from your PC or MAC Very low jitter oscillators and proprietary drivers Compact size (2x2.2x10.2cm) with hi-end performances hiFace USB interface has been conceived to obtain the highest quality digital audio signal using a PC or MAC. hiFace input format is a data stream signal with sampling frequency/resolution up to 192kHz/24bits, available from a PC or MAC USB port. A very high quality S/PDIF stereo audio output signal is available from hiFace for your Hi-Fi system DAC (Digital to Analog Converter). Hi-Face looks like a small USB pen drive, featuring a very compact size. Internal very low jitter oscillators and proprietary drivers allow for playing 192kHz/24bits audio files that feature the best signal quality.
FEATURES
1) LOW JITTER, LOW PHASE NOISE, HIGH STABILITY OSCILLATORS
Most audio interfaces and USB-provided DAC's refer the data stream clock to the same USB interface clock, that often suffers a very heavy jitter (short range oscillator frequency variations). Thanks to two quartz precision oscillators used on M2Tech hiFace, clock source for output data stream features a very low jitter. A more stable clock is recovered by DAC S/PDIF receiver; a low jitter produces a very limited sound image distortion and degradation. Phase noise (main responsible for jitter) is also very low: this guarantees a short and long range clock stability, also reinforced by a board supply voltage regulation (e.g. at environmental temperature stability is 2-5ppm approximately, compared to 50-100ppm performed by oscillators normally used on commercial CD players).
2) PROPRIETARY DRIVERS
The standard audio drivers available on the market (e.g. Microsoft Windows operating system) dictated constraints can be overcome thanks to hiFace proprietary drivers: they allow for transferring audio data, maintaining the original file quality without any loss of resolution quality; also, sampling frequency constraints are overcome, while Microsoft and ASIO drivers oblige to operate at no more than 96kHz. When hiFace is used together with a player application such as FooBar (available for free on Internet), you can transfer S/PDIF stream music files to a D/A converter at 192kHz/24bits maximum frequency/resolution, avoiding undesired PC or MAC audio mixer data processing during the data transfer from hard disk to interface. Presently, Windows XP, Vista, Windows 7 drivers are available, as well as Mac drivers for 10.4, 10.5 and 10.6.
3) COMPACT SIZE AND EASE OF USE
M2Tech hiFace features a very compact size and can be directly (or using an accessory USB A-A adapter, not supplied with hiFace) connected to a High Speed USB 2.0 port of any computer. A very high electric and mechanical performance BNC Silver plated connector provides an output signal, ready to be connected to a Hi-End system. No external power supply is required, as hiFace draws its power from USB bus itself and regulates it with its internal regulators. hiFace USB interface connected to a last generation mini PC provided with a High Speed USB port makes for a complete music transport system at very low prices (in the range of few hundred Euros). Such system allows for listening any density and resolution music files, playing own CD's using a CD ROM drive, obtaining access to more than 10,000 web radio, many of which broadcast their transmissions with CD quality.
SPECIFICATIONS
Connections
Input 1 x USB A type male
Output 1 x RCA female
I/O Standard
Input USB 2.0 Format
Output S/PDIF Stereo Digital Audio Format
Sampling Frequency
44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4khZ, 192kHz
Resolution 16 up to 24 bit
Dimensions 10.2(d) x 2.2(h) x 2(w) cm
Power Supply 5V DC from USB bus
Temperature from 0°C to 70°C
Weight 50gr approx.
« Last Edit: 13 Jan 2013, 09:23 pm by coverto »
coverto
Re: M2Tech Hiface with modded Mojo Audio SPDIF cable
« Reply #1 on: 1 May 2012, 07:53 am »
Bump.
coverto
« Reply #2 on: 4 May 2012, 04:06 am »
Price drop to $225 plus shipping.
coverto
« Reply #3 on: 6 Nov 2012, 06:16 am »
Bump.
coverto
« Reply #4 on: 24 Nov 2012, 04:57 pm »
Bump and price drop to $200.
coverto
« Reply #5 on: 4 Dec 2012, 05:34 am »
Bump and price drop to $175.
coverto
« Reply #6 on: 13 Jan 2013, 07:26 pm »
Bump and price drop to $150.
coverto
« Reply #7 on: 25 Jan 2013, 02:56 am »
Bump.
coverto
« Reply #8 on: 30 Aug 2013, 01:51 am »
Bump.
