0 Members and 1 Guest are viewing this topic. Read 9181 times.
recently the response seems a little muddy, am thinking due to age the caps could use a mod. I am driving these beasts with an original Threshold S500 firt edition Stasis amp, it alone will reveal deficiencies, and drive these M3's into the stratosphere, any help on cap determination as well as dealer availability would be appreciated.
I would suggest polyester film caps
film caps, assuming they are (as they almost certainly should be) non-polar
OK, film caps don't have, don't need a polarity. Since a capacitor is an AC device then theoretically a capacitor has no polarity. The only reason why electrolytic capacitors are 'polarized' is because the electrolyte needs it.
I understand that perfectly. I am noting that the *originals* should be non-polarized. Some "audiophile" components, however, use electrolytics/tantalum polarized caps in places where they are NOT biased and should in fact be non-polarized. Brett
Cool, I'm glad that you do, many people don't.I personally wont use electrolytics in passive crossovers unless I absolutely have no other choice.Anathema.
Agreed. That's also why I at least suspect that the problem is not in the crossover. Assuming they did it right and used proper film caps in the first place, from that era, they should have good reliability. NP electrolytics, maybe bad. If they uses polarized caps in an unbiased application, they would likely have blown long ago. I would look upstream of the speakers. Brett
Still though, I'd open up and look inside the loudspeakers just to be sure.
I doubt you can tell much by just looking. If you are going to actually start testing parts, then it has to be disassembled, so might as well replace the parts anyway. BTW , if it is determined to replace the the parts, get a bunch of them of each capacity needed, and then pick those closest to each other. The absolute value of the part doesn't matter but matching them from side to side is pretty important. Brett
Hi Knabelmarc, I did upgrade the caps in a pair of Mirage M3si's. I requested a copy of the schematic from Mirage and they sent it to me. I believe if I look hard enough I can still find a copy of it. The biggest problem that I ran into is that the board has around 29 parts on it. It is laid out so that their parts fit close to each other. Most high end caps are generally much larger than the caps that the factory uses. You are gong to find that the caps from Parts Express for the same value as the factory ones are 3 times the size. You will have a fun time trying to shoe horn the caps in. I would also consider changing the resistors to the Mills resistors that Parts Express sells. It made a positive change but with all of the crossover parts inside, it will cost you a lot of money. Not sure if it is worth it for those speakers because of all of the parts in the crossover. For it to be the best, you may end up having make up a new X-over board and lay it out with the larger caps. Coils would be a good thing but no room with the stock board.
As I recall they are second-order filters, not typical first-order, so there are going to be a lot of parts. Conventional caps from today will be no larger than the originals and likely smaller.
