Shuguang S300Mk SET Integrated: $999. Price drop.....
0 Members and 1 Guest are viewing this topic. Read 7188 times.
morganc
Up for sale is my Shuguang 300 SET Integrated.  This is an amazing entry level SET 300 B INtegrated that plays well above its price point.  It includes Black Treasure Tubes with less than 500 hours on them.
Here is the info for the amp from the Grant Fidelity Website.  Please note this amp at this price includes the Black Treasure 300 B pair and the Black Treasure 6CA7 pair.
"When this amplifier hits the market (shortly) at Grant Fidelity, it’ll be a giant-killer, as a majority of its MSRP would be the cost of its excellent tubes alone. I have been extremely happy with the Shuguang Audio S300MK Integrated Amplifier with Shuguang Treasure tubes, and I have yet to find a better match to my horns. Bravo, Shuguang Audio & Grant Fidelity!"
Jake Montzingo, Publisher, Affordable $$ Audio. Full review here.
Shuguang Treasure Classic series of tube amplifiers are designed and manufactured by the well-known Chinese tube manufacturer - Shuguang Audio and it is the 4th generation from their very first design of tube amps around the Shuguang tubes in 1990s. This time the high end Treasure tubes are used throughout the line to achieve the best sound.
The complete design was to achieve the maximum synergy between the circuit and the highly sought-after Shuguang Treasure tubes. To keep the complete amp affordable to all consumers, no fancy casing, no extravagant capacitors and no shiny lights but under the cover, you will see an extremely well designed and well implemented classic 300B single ended triode tube amp.
It's a classic look with one of the best current production tubes installed to give you the absolute high fidelity sound.
For DIY-ers, this amp also offers you plenty of room to hot rod and experiment what you can ultimately get out of these Treasure tubes by using different capacitors. For music-loving consumers, you can simply sit back and enjoy the glow of Treasure tubes and the beautiful 300B sound.
Recommended to match to speakers with efficiency at least 87 dB and best matched to horn loaded speakers or coaxial speakers to produce sonic magic. Of course it will still sound great with any high-quality speaker design. Many at shows have heard this 300B SET amp drive our 84dB Reality LS3/5A speakers with ease to enough volume for most. The combination is amazing. The EL34 driver tube is what provides this amp with what we like to refer to as torque, enough to drive stubborn low efficiency panel speakers as well !
Features:
Single ended triode Class A design with tube rectification
Point-to-Point copper/silver hand wired throughout, point to point
Oversized hand wound 115V transformers with OFC copper wire from Taiwan
6CA7(EL34) used as driver tubes instead of 6SN7 - drastically improve the bottom end of 300B performance and the depth of soundstage
At key points, Rubycon and MKP capacitors are used
ALPS volume control and WBT connectors
Tube protection cage included for your convenience
Aluminum remote control included
Tubes included:
(1) pair of Shuguang Treasure Premium Grade factory matched 300B-Z tubes
(1) pair of Shuguang Treasure Premium Grade factory matched 6CA7-Z tubes
(1) pair of Shuguang export grade gold label 12AX7
(2) Shuguang export grade 5AR4
Specifications:
Input impedance: 100 kohm
Input voltage: <=350mV
Output power: 2 x 8 W
Output impedance: 4 ohm and 8 ohm
Frequency Response Range: 12 Hz to 25kHz
THD: <=1%
S/N Ratio: 80 dB
Power supply: AC117V 50/60Hz +/-10%
Fuse: 250V 8A Fastblown
Net size: 16 1/8" W x 13 1/8" D x 8 1/4"H
Net weight: 23kg / 51 lbs
« Last Edit: 3 Jun 2012, 05:49 pm by morganc »
Gopher
Re: Shuguang S300Mk SET Integrated: $1150 for AC Members
« Reply #1 on: 16 Apr 2012, 02:38 am »
Thats a silly good price for this integrated!  I actually used to own the amp one above this in the line, the S845 MK and it was incredible with my Zu speakers.
Morgan's an awesome seller too... someone jump on it!
morganc
« Reply #2 on: 18 Apr 2012, 07:34 pm »
Thanks Gopher....It is a great little amp, works flawlessly and drives my Pendragons to much higher volumes than I can tolerate in my large living room. PM me with any questions.
Sam-fi
« Reply #3 on: 25 Apr 2012, 02:27 pm »
Having owned to the predecessor to this amp and used them with my Omen Defs I can vouch for it's insane quality for the price. Those treasure tubes just sound spectacular. AND having purchased a Melody amp from Morganc I can tell you he is a standup gentleman.
morganc
« Reply #4 on: 26 Apr 2012, 02:57 am »
Thanks Sam.   I'm glad you're enjoying the Melody I sent you last year :thumb:
morganc
« Reply #5 on: 27 Apr 2012, 02:35 am »
Price drop to $1100 .....  I can ship it tomorrow  :thumb:
« Last Edit: 3 Jun 2012, 05:48 pm by morganc »
morganc
Re: Shuguang S300Mk SET Integrated: price Drop $1075
« Reply #6 on: 5 May 2012, 03:35 am »
$1075......
morganc
Re: Shuguang S300Mk SET Integrated: $999. Price drop
« Reply #7 on: 3 Jun 2012, 05:48 pm »
Price Drop....$999 plus shipping, PP.
Tubes alone are worth around $500!  I've got too many amps......someone please take this fine one of my hands:).
It is rare to find a 300 Set integrated with remote at such a bargain of a price.........auto basing, perfect for beginners or those like myself who just want to simplify!
morganc
Re: Shuguang S300Mk SET Integrated: $999. Price drop.....
« Reply #8 on: 7 Jun 2012, 05:20 am »
Price drop.....$950...
morganc
« Reply #9 on: 10 Jun 2012, 12:48 am »
$900......cleaning out the house!  Help me get back in good graces  with the woman of the house   :thumb:
Lou62
« Reply #10 on: 14 Jun 2012, 06:58 pm »
Morgan,
I'm interested in this amp.
I sent a response to your messages file.
Chris
morganc
« Reply #11 on: 15 Jun 2012, 12:43 am »
Sale pending.......
ncblue
« Reply #12 on: 15 Jun 2012, 02:59 am »
If that sale falls through, PM me
