BDP-1 with Toshiba tablet
0 Members and 1 Guest are viewing this topic. Read 1317 times.
PRELUDE
« on: 15 Apr 2012, 06:04 pm »
Hi Folks,
I am curious if any one of you using the Toshiba Thrive tablet 10" with BDP-1 or would it be a good choice at all?
Here is the link.
http://www.toshibadirect.com/td/b2c/pdet.to?poid=2000003329
I travel a lot and like to have a tablet that has few full size ports so I can connect camera and other devices or it would be useless for me.So the IPAD is not for me and in few months I will buy the BDP-1 finally and I do not want to get another toy again.
Alpha10
Re: BDP-1 with Toshiba tablet
« Reply #1 on: 16 Apr 2012, 02:18 pm »
I have run the MPoid app on a few Android tablets and it works absolutely fine, so I would have thought you would be good to go.
Cheers
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 16 Apr 2012, 02:30 pm »
Also if you are using Android try this one with the BDP-1:
http://mpd.wikia.com/wiki/Client:Bitmpc
james
PRELUDE
« Reply #3 on: 16 Apr 2012, 11:20 pm »
Thanks :thumb:
I think I will order it.I have been around and this is the only one that I like.
