0 Members and 1 Guest are viewing this topic. Read 3483 times.
I should have saved my money and not bought the digital hasselblad in 2010!
Well, IF you're not using it, can I borrow it? (Yeah, that's me green with envy!)
How many shots did you shoot with the 4x5 verses what you'd normally shoot digitally? My understanding of ortho film is that since it's not sensitive to reds the flesh tones come out brighter than normal, right?
Hey! navi, very nice shots. There's still something about those little light sensitive salt crystals that digital sensor can't match when is come to B&W.Take care,Buddy
What digital does well is sharpness, low noise & colour intensity (that can be considered as lower dynamic range)The closest way to getting this tonal range with digital I've found is adjusting the raw file as a greyscale image and adding green and tweaking the red and blue channel
correct-O! ortho film on people look good because it's not sensitive to red- which is why i can develop under red light as well (developed in my bathroom). I didn't have to use a green filter like with normal BW film.I shot 10 shots. 5 looks 2 shots per look. If I had shot it digitally I would have BLASTED off about 200-300 frames. I'm shooting film for editorial work in the future.
I think I have been doing something similar to that. I desaturated the color and I use Channel Mixer on the CS2, works OK.
However, I am nearly convinced that you cannot reverse engineer the super old-school tintype, wet plate collodion etc. process with Photoshop\Lightroom. I am open to being proved wrong, but when I see one of those the combination of the ancient blurry glass, the grungy rough edges and the tones just seem like they can't be duplicated any other way. Way beyond my patience level, though.
