0 Members and 1 Guest are viewing this topic. Read 3314 times.
Can't answer your question but batteries might surprise you...
Oh so you are enjoying it? Did you switch back and forth between your batteries and regular supply? It's a pretty neat jump huh? ComebackKid I went from the 130 to a big linear supply to batteries. Batteries on this amp, are king, and will blow your mind.
If it’s not a Sensation, then I’m assuming that you mean to say that it’s either a ONE or TWO. You can usually tell the difference between these by the color of the badge on the front: red badge for the ONE and silver badge for the TWO. As to telling the difference between the first and second generation amps, you can tell the difference by looking at the way that the propeller posts are laid out on the back of the amp. The first generation amps had the posts set up horizontally, meaning that both red posts are located on the same side. The second generation (ONE.2 and TWO.2) have the posts set up vertically, with both of the red posts at the top and the black on the bottom. Here’s an image that illustrates this.Hope that’s what you were looking for the7comeback7kid.
