A new owner desperate
0 Members and 1 Guest are viewing this topic. Read 10247 times.
terrycym
Re: A new owner desperate
« Reply #40 on: 19 Apr 2012, 05:39 am »
Chris, James,
My sincere thanks for the latest beta update. All songs (in m4a and AIF) in the past refused by my BDP1 is now accepted since your the last beta update! Great work and great service :thumb:
Lucky you, I'm still struggling here.   :(
terrycym
« Reply #41 on: 19 Apr 2012, 01:04 pm »
Chris, James,
Is the ability to play hi-res ALAC a design feature of the new firmware?
Is this what I need to play my hi-res ALAC?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #42 on: 19 Apr 2012, 02:02 pm »
Hi Terry,
No - this is just the implementation of a new MAX 2 and we are using a more recent version of Linux.
james
NMG
« Reply #43 on: 20 Apr 2012, 01:59 pm »
I am not an Apple guy, but i thought to play hi-res in iTunes you had to change the resolution setting each time you were changing, i.e., it does not sense the resolution of the music you are playing and adapt automatically.
Don't know if this helps. I keep my music in iTunes and store on HDD connected to BDP-1, but for hi-res, I keep the music on a spearate thumb drive.
Neal
terrycym
« Reply #44 on: 20 Apr 2012, 02:06 pm »
Thanks mate for the help but I don't use iTunes so I can't comment.
The problem's on my BDP-1.
No sign of any fix either, ah well. At least the review in this month's Stereophile on the new Bryston processor was good.
