swiffer dusters work great on maggies
0 Members and 1 Guest are viewing this topic. Read 1550 times.
Rclark
« on: 10 Apr 2012, 09:21 pm »
I'm cleaning up my room preparing to do a little shootout between my Maggie's and the other two sets of speakers I have here and I realize I never mentioned this. People are often wondering how to clean their planars. I just use a swiffer on all surfaces, even the sock. Very easy to modulate how hard you apply pressure with the flexible grip and the swiffer itself really pulls that dust away
Just a cheap tip.
Rclark
Re: swiffer dusters work great on maggies
« Reply #1 on: 12 Apr 2012, 01:00 am »
 Good, nobody freaked out that I'm using these. Will continue to do so, these make mine look extra crispy and delicious, the sock too. I even go over the naked panel in the back with it.
AVnerdguy
« Reply #2 on: 12 Apr 2012, 02:18 am »
I do too. Started almost by accident. Was dusting the shelves with a Swiffer and the Maggies were right there so I started dusting the Mye Sound stands and then moved around the edges. Was wondering what would happen if i "dusted" the socks so I tried it on the back. Looked great and I could easily see where I did a pass so I did the entire speaker. Love how it works and its fast.
berni
  • Guest
« Reply #3 on: 12 Apr 2012, 06:29 am »
I also use the swiffer on Maggies especially on the cloth with great results.
