Favorite Low Watt Speakers (pictures welcomed)
0 Members and 1 Guest are viewing this topic. Read 74325 times.
Poultrygeist
Re: Favorite Low Watt Speakers (pictures welcomed)
« Reply #40 on: 17 May 2012, 06:53 pm »
More Frugal Horns. These are powered by a 2a3.
R_burke
« Reply #41 on: 28 May 2012, 03:30 pm »
How about some stand mounted Monitor type speakers, any favorites?
invstbiker
« Reply #42 on: 11 Jun 2012, 02:14 am »
my jbl 4345's driven by a 24 watt canary 300b tube jobby
Bemopti123
« Reply #43 on: 11 Jun 2012, 02:30 am »
WOW.
MartinV56
Docere
« Reply #45 on: 7 Jul 2012, 09:36 pm »
I have not heard (m)any high efficiency speaker systems. But my favourite is the system currently built for me by Ben Arends of Sound with Style: a bespoke 10+ cubic foot MLTL, designed by Scott Lindgren for the GPA 604-8H-III, running custom Rick Craig crossovers. It should be a lovely speaker, but perhaps more importantly it has been a very rewarding experience. Each of the people working on this project are very knowledgeable and a pleasure to work with.
Progress picture:
Ben is doing a really nice job of bringing out the beauty of the Red Heart Eucalypt. There is (at least) one more coat to be applied, then cutting and buffing. In his words, the finish will be "like glass". The rest of the speaker will be finished in 'piano' black.
Thanks for taking the time to look.
Raymond
Poultrygeist
« Reply #47 on: 7 Jul 2012, 10:15 pm »
Betsy/Alpha Open Baffles and Tang Band/Alpha H-frames in rear.
« Reply #48 on: 7 Jul 2012, 10:37 pm »
Hey Raymond,
How about some details on that speaker?
Looks like a monster from the spec sheet (121 dB/w/m at 8 ohms, 100 watt max input, F3=40 Hz if I'm reading it right).
I had 8 inch woofers in 6 cu. ft. MLTL's that were rated 114 dB at 17 Hz and they sounded space constrained until I tried them in a 20,000 cu. ft. chapel.
Docere
« Reply #49 on: 8 Jul 2012, 12:39 am »
Hi JLM,
Yes, the datasheet does make it seem like these are 121 dB/w/m at 8 ohms. My guess is that this is for the compression driver and that the mid-bass is significantly less efficient. At the bottom of the datasheet is a frequency plot (using the GPA crossover) that suggests in-cabinet efficiency ~99 dB/w/m at 8 ohms from 50Hz upwards; a ‘better’ cabinet and room-gain will extend bass evenly below that. Great Plains Audio seems to provide realistic specifications, so I am inclined to trust the plot.
They are beasts of drivers and very well suited to being driven by SET amps – this was one of my criteria for selecting them. That said, I would probably not have chosen them if not for the Rick Craig crossovers being available and knowing I could have a decent cabinet designed them.
After I have had some time with them I will share my impressions etc. in a thread here. I’d also like to present the project in some way, without giving away Scott’s or Rick’s designs – something that could help people decide whether such a system would be appropriate for them, what types of issues need to be considered and point them in the direction of knowledgeable people that can help them along the way. I have some ideas for a simple web site, but my time is limited.
Raymond.
emmvette
« Reply #50 on: 11 Jul 2012, 12:07 am »
Klipsch Cornwalls. I have Khorns and Heresy as well, but the Cornwalls sound good on everything and are easy to please regarding the components you use in front of them.
Of course the Khorns sound awesome, but you have to have corners and good equipment to use with them.
Bemopti123
« Reply #51 on: 11 Jul 2012, 12:47 am »
Horns, Horns
My horn system
More Horns
http://www.hifichile.cl/index.php?/topic/921-horns/page__pid__137537__st__1890#entry137537
What units are you running in these?  What crossover points?
Looking good, from NYC :thumb:
MartinV56
« Reply #52 on: 17 Jul 2012, 09:51 pm »
Bass: Eminence Beta 10" BLR horn
Midrange: Klipsch K55V or Pyle Pro PD 772
HF: Selenium D220 ti
bass: 800Hz
Mid: 800Hz 7Khz
HF >7Hz
Whitese
« Reply #53 on: 21 Aug 2012, 01:58 am »
EV15TRX
EV12TRXB
aragon63
« Reply #54 on: 23 Apr 2013, 02:08 pm »
 WBA Betsy's in OB.
« Last Edit: 18 Oct 2013, 07:35 pm by aragon63 »
« Reply #55 on: 23 Apr 2013, 03:02 pm »
Someone can identify this OB woofer??
Initially I thought it was the Fostex FW 31 inches woofer but this is much bigger:
The small FR on the floor is a Feastrex.
Corradobrit
« Reply #56 on: 24 Apr 2013, 03:15 am »
My friends KCS BLH with Fostex FE206ES-R enabled by Dave @ Planet 10 sounded really good.
aragon63
« Reply #57 on: 3 Jul 2013, 12:56 am »
Madisound BK-12m folded horn ( FE126En )
Bemopti123
« Reply #58 on: 3 Jul 2013, 01:07 am »
Awesome.  How do you describe their sonic signature?
What made you chose those drivers rather than other ones?
Paul NYC
InfernoSTi
« Reply #59 on: 3 Jul 2013, 01:16 am »
I realized I had never updated my posting with the full Hawthorne Audio Reference K2s. The main speakers have a waveguide AMT tweeter and 15" mid-woofers.  The secondary towers have 15" Augie woofers x2 each.  Yep, that is 8 x 15" mid and woofers plus two 100db AMTs (crossed over about 1,000hz). All driven by a 2A3 Bottlehead amp and two Rythmik 370 watt OB plate amps (for the two Augie towers).  Here is a full room photo:
Best,
John
