0 Members and 1 Guest are viewing this topic. Read 6126 times.
I'm a PC, but the MiniDSP site says it's compatible with MacOSX. Assuming it's all the same after that, you just need something with a USB port and a screen. Shake hands with the DSP board, brings up your control panel, can set XO points/slopes/phase/EQ etc etc from there. Once your good with your settings, save the data and you can unhook the USB until your readty to change something again.
I should probably research a little deeper (just lazy I guess), but my understanding is that the USB is not used to stream data, but for power and control only, so a standalone "minidsp in a box" would need some type of power supply and data connection - i.e. at least 2 cables - not of itself and issue. From my few experiments, the analog audio out on any of the Mac devices is, ahem, not their strong suit, while the digital audio options are Toslink (mini on the MBP), USB, Firewire, or most recently, Thunderbolt.
open question to minidsp users - what would be considered a minimal configuration for FR + helper ( or "FAST" as it's sometimes called)
In all cases, you need to make sure that you have a good "gain structure" - if your line level signals are > 0.9V you'll have issues.
The minimal configuration is a single 2x4 (in a box) which has analog in and out. You use USB to program the settings only. For how-to-use, this may help: http://www.hifizine.com/2010/09/subwoofer-equalization-and-integration-with-the-minidsp-2x4/
