0 Members and 1 Guest are viewing this topic. Read 5562 times.
Come on Davey, you know they can't track, they hum, and they have been known to steal your stuff when you're not looking.
Just checked my home insurance - Am not covered for that third Grado quirk you mention Mitsu Will keep a close eye on my gear while it's on the Ittok - thanks for the tip off The first two I am familiar with;Re. tracking - I know there's many who have no problem with any Grado, personally I have had issues with IGD and sibilance with the Prestige line stylii.Regardless of which alignment technique employed, I have struggled to get these rather chunky, bonded and not particularly highly polished diamonds to give as clean a presentation on inner tracks as other similarly priced carts (eg. AT 440Mla, Denon DL160, Ortofon 530 etc.).Grado GoldThe MCZ is far superior in this respect.Re. Hum - Yep! On the Sondek there is a small amount that gradually increases in volume as it tracks closer to the motor.But it's at such a low level (I have to have the volume knob at 12 o'clock to hear it) that it is not audible when playing a record, even in very quiet passages.It's certainly worth doing a little research on Hum susceptibility with your deck if you are considering a Grado, some are worse than others.CheersDave
Many have stated that the Grado has a tracking problem, regardless of alignment. That should send a message that the problem isn't the alignment, but rather, the stylus rake angle (SRA) that can be finicky with the Prestige line.A couple of fellows named Risch and Maier experimented with SRA and thru measurement and trial and error, concluded that the ideal SRA for almost any stylus, played on any LP is 92°.I run my Longhorn at this angle and it plows thru everything. I believe that almost all prestige cartridges will have a 90° SRA when the arm is parallel to the record surface, with the stylus in the groove. To get to 92° you are going to have to raise the VTA of the tonearm by 8mm, or .31 inches (5/16").The only analogy I can apply here is fingers on the chalk board. Put your fingers on a table top surface so they are 90° and pull it towards you. You can feel, a vibration. Now lean the top of the fingers away from you and do the same thing. There is a different feel. That's what the cartridge is going thru.Wayner
My 8MZ stylus will be here Tuesday. I can't wait to pair it with my Longhorned Gold1. Any other setup tips Marc?
