Bryston Speaker Switch Box
0 Members and 1 Guest are viewing this topic. Read 2598 times.
grayzone
« on: 8 Apr 2012, 02:53 pm »
Would a Bryston speaker box work in reverse?
I have different amps I would like to use with a set of speakers or is the best solution just to physically move the speaker wires?
thanks al
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Speaker Switch Box
« Reply #1 on: 8 Apr 2012, 03:18 pm »
Sorry no al.
james
grayzone
« Reply #2 on: 9 Apr 2012, 02:21 pm »
Any ideals what is the best alternative other than wire changing,that will work as a speaker box in reverse?
thanks al
achappy
« Reply #3 on: 25 Aug 2012, 04:33 am »
Even though the switch box states that it is for 1 amp switching between 2 (or more depending on which switch box you buy) sets of stereo speakers, since internally there are only mechanical gates opening and closing, you should be able to reverse it: connect your amps to the speakers posts and connect the speaker to the amp posts.  Same principle: gate A closes and the signal (direction is irrelevant) flows from the amp that is connected to the gate A posts to the speakers connected to the amp posts; the same for the gate B amp.
Buy the Bryston Switchbox from someone like AudioAdvisor.com and you can return it within 30 days for a full refund less shipping.  And you can test it.
